1986 Honda VFR 700 interceptor "engine markings"?
Discussion in '1st & 2nd Generation 1983-1989' started by Jabrony, Feb 8, 2015.
  1. Jabrony
    Jabrony New Member
    To the gurus out there....are these normal production markings?
    They are made with paint pen, my fear is that they look like junkyard markings.......
    The pink "AKS" is the front bank of cylinders.
    Please advise...
    Thank you
    John
  2. Allyance
    Allyance Insider
    East Bay, California
    Definitely junk yard or a shop that had engine apart.
  3. fredsncoma
    fredsncoma New Member
    Gardnerville, Nevada, United States
    I do believe I have seen those on the 86 and 87's that I have torn apart and they were not from junkyards. So I am going with production. Let's let Toecutter chimp in.
  4. TOE CUTTER
  5. Jabrony
    Jabrony New Member
    Awesome, thanks for your help!
  6. Allyance
    Allyance Insider
    Why only '87 & '87? I have two original '83 engines (one in pieces) and I have never seen those markings.
  7. squirrelman
    Never saw a VFR700/750 engine without those cryptic, vari-colored inscriptions. I think they must be code to id which team assembled which parts or to code it for any production-line mods or dates of construction. Just think: Some Japanese worker got up one morning, ate his cold rice breakfast, trained it to the Honda factory, then put HIS PERSONAL signature or chop on YOUR unique bike on one day in history !!! Then he trained home an hour or more, had more rice for dinner, and it was another ordinary day for him; but for you it was the exact day Honda built your favorite bike. A day of history, not of infamy.
    That's special and makes every '86/'87 VFR "signed by an artist".
    BTW: Don't turn up your nose at junkyard parts as most are as reliable as anything from a private seller.
  8. dcompson
    dcompson New Member
    My 85 vf1000r has similar markings in the same locations.
  9. Jabrony
    Jabrony New Member
  10. BluRoad
    BluRoad New Member
    Antioch, IL
    I've seen these on a few of my '86-87s and a super lo-mile, all-original '92 CB750 I had; always in a light blue color.
  11. desktopdave
    desktopdave New Member
    Pittsburgh, PA
    I had noticed them on my '86 too. I figured the same as you did, but now I'm thrilled to find that I have a limited edition signed copy. :congratulatory:
    [​IMG] [​IMG]
    There they are, both front and rear. I know the bike is a mess, I'll clean it up eventually! I've had a few bigger fish to fry with this bike so far...
  12. desktopdave
    Pittsburgh, PA
    I just wanted to add that I found the same markings on a VF1100s engine. They're on the rear of the block, impossible to see when the exhaust resonator is installed.
  13. thx1138
    thx1138 New Member
    Perth
    On all my VF engines, including nos VF1000 crankcase set. I think it identifies matched uppers and lowers after line boring of main bearings.
  14. desktopdave
    Pittsburgh, PA
    I'll bet that's it - excellent guess. It makes sense that the VF1100s block would have been marked instead of the heads; only the bottom end was line-bored on those motors.
  15. Maggot
    Maggot New Member
    Park Ridge, IL
    I work for a company that makes those type of markers and we sell them to automotive plants in the US. Most of them are used for quality control. We sell many to a Toyota Plant in Evansville IN. They put over 30 of those type of quality control marks on the seat assembly alone. All before it is covered in fabric.
    Check out www.markal.com for all kinds of markers. they will even send you free samples!
  16. chuntera
    chuntera New Member
    Connecticut, USA
    I believe the 2nd gens were assembled at the goldwing plant in Marysville, OH. Interesting if any goldwins had the same markings (my 2nd gen does not have those).
  17. pchmotoho
    pchmotoho New Member
    So. Cal
    I just noticed those same marking the other night while semi restoring my 86 750. I have owned it since 1992.
  18. NormK
    NormK New Member
    Pretty sure I have them on my 86 as well, I just thought they must have been breakers parts, never took any more notice
