1986 Honda VFR750F
Discussion in 'Specifications' started by michael, Jan 29, 2006.
  1. keny
    keny New Member
    Finland
    city of Karjaa, Finland North Europe
    It's 355mm long
    #61
    Well, blows my theory out the window. Weird.
    #62
  3. keny
    keny New Member
    Finland
    I did look at YSS site, no logic in witch length has adjustment and not, mostly fork lower shocks that are short doesn't have but there is exeptons
    #63
  4. keny
    keny New Member
    Finland
    I wounder if you know how much the 87 shock rise the rear on a 86, at wheel axle.
    #64
    In a very unscientific quick check:
    Two 1986, both on sidestands, similar preload settings, from the axle to the same spot on the subframe...
    The 10mm difference in shock length resulted in a 1 inch increase.
    #65
    keny likes this.
  6. keny
    keny New Member
    Finland
    Well search for orginal shock numbers give you 4 different shock's used on the RC24
    ML7-003 as ML7-013 for the 1986 750 as 700.
    ML7-691 for 1987 750 as 700
    ML7-921 for the 1988 as 1989 750
    Would be interesting to know what difference between the 87 as 88/89 shock even same length as look....
    #66
    The 88-89 is the same length as 87. Likely is a valving / spring change that resulted in a different part #.
    If I remember correctly, visually they look the same 87 to 88.
    #67
  8. keny
    keny New Member
    Finland
    Yes, actually 86 to 89 looks alike I think. I have hade a 87 that stock shock felt almost as soft as a 86 shock, I have test ridden a 89 and its shock didn't feel as soft so yes, probably a spring/valving change
    #68
    The 86 is actually much different looking from 87 on. It has a boot covering the preload collar and a different pre-load adjuster.
    #69
  10. keny
    keny New Member
    Finland
    Well yes, the 86 is slightly different, also the lower spring plate seems different actually
    1986
    1988-89
    1987
    #70
  11. keny
    keny New Member
    Finland
    What do you mean by "Sprung" for the 87 camshafts?
    My other 86 rear cylinder head exhaust camshaft is not good anymore sadly, so looking into camshafts, a cheap 87 bike would be possible to get (has been down/fallen) so wounder if you could use 87 cams in a 86, aside the one that trigger the sensor (front cylinder head intake), whit out any issues?
    #71
  12. squirrelman
    i have 750 race cams in a box under a bench somewhere.
    stock at left
    #72
