1986 vf500 ... i screwed up
Discussion in 'Mechanics Garage' started by fastenough, Jun 22, 2014.
  1. fastenough
    fastenough New Member
    i over torqued my valve cover bolts, and snapped one.
    i have new bolts, and a new camshaft holder (the cover bolts to the holder) already ordered and coming.
    for the time being, my bike is in a garage, and i have shop towels between the cover and the head. i put the cover back on, and tightened the 3 bolts that i can tighten back down by hand, with shop towels covering the ends of the cam shafts where the gasket would normally go, and the hole for the missing bolt
    do i need to worry too much about moisture or rust forming in there? its not going to get rained on and the most moisture it will encounter is humidity...
    im just being paranoid now that i idioted myself into this situation :/
    thanks
    Next time use a 1/4" drive setup to tighten those bolts, OK ??
  3. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    No you don't need to worry about a little moisture in your engine. It gets condensation inside every time there is a heat/cool cycle anyway and the parts are coated in an oil film for the most part. That condensation evaporates when the engine warms up on your next ride.
  4. FMB42
    FMB42 New Member
    The towels are unnecessary imo (they might even attract moisture). Meanwhile, I'd double check that you have disconnected the battery terminals (accidentally cranking the starter could damage your semi-assembled engine).
    Meanwhile, keep in mind that everyone makes mistakes...
  5. nearfreezing
    nearfreezing New Member
    Worcester, MA
    No need to worry about moisture. Not sure if those bolts have torque specs, but if they do, good idea to use a torque wrench next time.
  6. fastenough
    i did :(
    i did the math wrong though, torque specs are 6-9FT-LBS, i converted to inch-lbs wrong and snapped it :( my own dumbass mistake.
  7. fastenough
    ya, i thought the same and removed the towels. i put the whole thing back together, with the gasket, just to be safe
  8. fastenough
    does anyone have any experience (or "one of your friends" ;)) with breaking a valve cover bolt?
    i've ordered a new set of bolts, and a set of camshaft holders...
    In every case where I've seen a valve cover bolt broken off in the cam holder, it can be backed out with a dental pick or something similar. Prob seen it more than 10 times.
  10. fastenough
    this is true.
    i managed to work the broken part out with a bunch of lubricant and some picks, it took a lot of coaxing but i finally did it.
    im happy about this because i am re-using the same cam holder, i was worried about slight wear variations in a replacement (used) one.
    i also brought my FT-lbs torque wrench home from work, and checked every bolt with that :)
    i buttoned everything up, tested, and took it for a ride. everything is great.
    when i got back i gave the in-lbs torque wrench the finger.
