1986 VF500F almost back to life
Discussion in '1st & 2nd Generation 1983-1989' started by Chocula, Sep 19, 2014.
  1. 74ullc
    74ullc New Member
    Gulf Coast, Texas
    Lol....Don't you?
  2. Chocula
    Chocula New Member
    At this point the bike is running pretty well. A few minor things to fix, but nothing critical. I have put a couple of hundred miles on her this past month and just rolled past 20K on the odometer this week.
    I synchronized the carburetors which helped quite a bit, then sort of rebuilt the petcock. The interior gasket had worn down and the one I ordered hoping it would fit was way to small. I flipped the gasket over and moved the worn area next to the metal post instead of at the holes. I also removed the modification the shop made to have it work as a manual only petcock and restored the vacuum operation with a few new parts. At this point gas flows when it should and doesn't it should not. I replaced the coolant again which was gross, but not nearly as bad as before.
    She still has a little roughness at highway speeds. Valve adjustments will be my next project, hopefully that will help. The more I work on her, the more disappointed I am in the shop that I had do some work earlier. I expected them to do a better job than I would be able to which does not seem to be the case. I suspect I will be happier doing everything myself from now on.
  3. Maggot
    Maggot New Member
    Park Ridge, IL
    Always better if you have the knowledge to do it yourself. Nobody cares more than you!
