Accessories for Sale 1986 VF500F partout
Discussion in 'Classifieds' started by mikemo, Dec 10, 2020.
  1. mikemo
    mikemo New Member
    Palm Harbor, FL
    Located in Palm Harbor, FL (near Tampa/Clearwater).
    This was a running bike, but the front cylinder head was in need of expensive repair, so I'm moving on.
    You can DM me or email me at zfreak@gmail.com for details.
    Buyer pays actual shipping. If you don't like the price, make an offer.
    Ignition switch with harness, with one original Honda key, with matching fuel cap and seat/helmet lock - $50
    Igniters (spark boxes) - tested- from V4Spark.com for 1986 vf500f $100 for both ($160 new)
    1986 frame with clean/clear Florida title in my name $100
    Main harness $40
    Regulator - tested - $25
    fuse box $30
    left controls with harness and choke cable $20
    right controls with harness and throttle cables (throttle cables work, but are worn) $20
    Brake hydraulics (calipers, master cylinders, lines) offer?
    Clutch slave cylinder, hard lines, etc offer?
    Miscellaneous bottom-end engine parts. Ask for what you need.
    Front forks, black. Not leaking. $60
    wheels $30 each
    headlight / fairing frame
    grab handle
    coolant tank
    horn
    tail light
    Most other bits as well. Just ask.
    PM sent about shock
  3. Jim McCulloch
    Jim McCulloch Member
    Good stuff here! Hopefully after Xmas I will have more money! Thanks for getting the parts for me so quick.
  4. mikemo
    mikemo New Member
    Palm Harbor, FL
    Here's a few more details and pictures for those interested. Again, if you don't like the price, make an offer. Thanks.
    Frame, with clean/clear Florida title in my name $100
    Rear inner plastic fender $20
    Wheels, no damage. $50 each
    Forks, straight. One tiny spot of pitting on right fork, but well above where the seal normally rides. The rest of the chrome is clean. No leaks that I could see, but I would replace the seals anyway. $50 each
    Center muffler. Good condition with some surface rust. $50
    Left-side muffler. Some scratches, but functional. $50
    Thanks.
    Mike M.
  5. HamHock
    HamHock New Member
    I'm looking for the fuse box cover that goes on the top bridge, do you still have it?
  6. mikemo
    mikemo New Member
    Palm Harbor, FL
    Sure do. It had a sticker on it that left some residue. It is also a bit faded, but should repaint nicely with good aerosol plastic paint.
  7. HamHock
    HamHock New Member
    PM sent.
  8. Jim McCulloch
    Awesome, hard part to find! Use black bumper trim paint on it. Will look like new!
    HamHock likes this.
  9. mikemo
    mikemo New Member
    Palm Harbor, FL
    I updated the lists above and deleted what has been sold. I have a few other parts I'd like to list here.
    Carb insulators, OEM, still flexible, with clamps.
    Battery box.
    Headlight.
    Starter motor (tested), with cable.
    Starter solenoid.
    Horn.
    Rear brake pedal.
    Rear brake fluid reservoir.
    Driver's foot pegs, with brackets.
    Valve cover bolts with rubber seals (x10)
    Rear head coolant pipe.
    Intake and exhaust valves.
    Airbox with K&N air filter.
    That's pretty much all that's left. Everything else was sold or was just too nasty to save and sell. If you have questions or want pictures, just let me know. Direct email at zfreak@gmail.com is best, but pm is also fine.
    Thanks!
    Jim McCulloch likes this.
  10. Thorinn Oakunsheyld
    Thorinn Oakunsheyld New Member
    Penticton BC
    Hi there; interested in your starter solenoid. Also looking for right side control (or bits and pieces) and petcock (especially intake tube, strainer and vacuum assembly portion. Located in Canada so would be willing to entirely prepay. In no rush, have a spare incomplete petcock. Just looking for hard to find bits and pieces before I need them. Let me know if you have any of this, and preferred payment. Old guy, haven't dealt in paypal or other methods. Happy to send US money order. Cheers... Thorinn
  11. Thorinn Oakunsheyld
    Penticton BC
    This is my spare petcock.
