1986 VFR 700F2 wiring harness?
Discussion in '1st & 2nd Generation 1983-1989' started by Drod, Jun 16, 2012.
  1. Drod
    Drod New Member
    Anyone have a decent wiring harness for an '86 vfr 700f2 ? i think i have a short somewhere and can't find it so far.....no juice to the key but all the other parts have checked out so far like battery, r/r, ignition, all fuses and connections....thanks in advance.
  2. malaguchi
    malaguchi New Member
    Might look at kycyclesalvage.com. Seems like the white color scheme was 2nd half of 86 and 1st half of 87. Would need to be sure the ignition system is the same. might PM squirrelman on that question.
  3. TOE CUTTER
    Check the fuse in the starter relay.
  4. crustyrider
    crustyrider New Member
    North Country, New York
    yeah what TOE said..
  5. TOE CUTTER
    The fuse in the relay is gonna be a non traditional fuse, it is just a strip of metal that bridges the posts.
  6. Drod
    Drod New Member
    checked all the fuses...in the starter relay i have a 30 amp fuse, which is fine...don't know about a metal strip? still think it must be a wire somewhere in the harness, still no luck
  7. TOE CUTTER
    The power to the ignition switch is a red wire that runs directly from the starter relay to the ignition switch. Have you checked the connection from the harness to the ignition switch? This should be really easy to locate the open in the circuit.
  8. Drod
    Drod New Member
    I'm trying to check the wires now. have a question on the starter relay does the top red part pull off? DSCN0759.jpg DSCN0758.jpg
  9. McViffer
    McViffer New Member
    Northern California
    YES. Pinch and shivvy it off. The 2 returns from the RR are a common point of failure on this bike. If they melt the connector, there be a ground in there that could very well be your short. Pick up a book if you dont have one. I think there is a PDF around here somewhere if you search.
  10. Drod
    Drod New Member
    I have a manual but doesn't say much about the relay...i tried to get it off but didn't want to break it...maybe that's the problem....i already changed out the r/r and those connections were fine and clean. thanks for the input, dave
  11. Drod
    Drod New Member
    yes yes yes... i got it fixed....finally got the starter relay pulled apart and yes that's where the problem was...cleaned it up and switched the fuse and it starts.....thank you guys for all the help......the vfr guys are the best for help!
  12. squirrelman
    Persistance pays off, and it's usually better to track down a problem than just throw new parts into the equasion, huh ??
    Can you post a photo of what you discovered under the red plug ??
  13. Drod
    Drod New Member
    got it all back together so don't have a photo...but it was a burned connection going to the r/r typical stuff for our vfr's... it was jut a problem getting the top off the starter relay...they kind of melt together. thanks
  14. TOE CUTTER
    I LOVE A HAPPY ENDING! :Cry:
  15. TOE CUTTER
    A deep fat fried connector is normal. Nature of the beast....... :Cry: I am all verklempt.
  16. crustyrider
    Your a happy ending TOE....
