1986 VFR RestoMod out of parts
Discussion in '1st & 2nd Generation 1983-1989' started by Captain 80s, Dec 27, 2014.
    F3 rear wheel looking tasty. Still in the booth.
    Bazza and RogueRC24 like this.
  2. RogueRC24
    So jelly. Lookin noice!
    Bazza likes this.
  4. sixdog
    sixdog Insider
  5. RogueRC24
    Ohh Yeah!! think Kool-Aid.
  6. rc24dk
    rc24dk New Member
    Netherlands
    Denmark, DK
    "80s" then ? :)
    RogueRC24 likes this.
    Tubes checked for dings, a few swipes of 1500 sandpaper, then polished out with Mothers. Donor 1990 VFR forks bought for the chrome tubes somehow had perfect bushings. Internals are from the 1992 VFR (which got 97 forks), pretty sure 92 got updated valving from 91, so I went with them (why not?). RT springs. The F3 rebound adjusters are frozen (common), so they are soaking in Marvel Mystery Oil, maybe at some point those internals can be used as intended.
    RogueRC24, Bazza and sixdog like this.
  8. RogueRC24
    Those look like one of my ST1100 fork innards.
    The highlighted blue interface parts were the parts giving me trouble. I had to polish each component so they would sit correctly. Funny how many parts are interchangeable between Hondas. PXL_20250103_040223972.jpg
    I'm still confused about what was wrong. The springs just rest against those landings.
    If you are referring to the dished/slotted washer (not shown in my pic), that goes on top, right below the nut. It is responsible for holding preload pressure against the spring. #15
  10. RogueRC24
    The landing on the damper rod (across from item #5) was not seating on the damper rod due to metal burs. That in turn was not allowing the spring to be compressed enough to to fit the slotted washer at the top. I then realized that I could unthread the top nut a bit to allow the slotted washer to fit, once I polished the "spring landing" on the damper rod.
    Maybe that makes sense now? Every fork I have taken apart has been different so I am always learning how to f it up.
    Still absolutely confused.
    What does that mean? The landing is not a separate piece on the Damper unit. The spring rides right on top, nothing in between. Was/is it broken?
  12. RogueRC24
    Yeah, that hat with all of the radial holes that the spring rests on was separate. It is not one with the damper rod. Might have originally been a press fit. All I know is that it fell out with the damper once I got the bottom bolt out.
    Ooooof. Now I understand. I have never seen that.
  15. sixdog
    sixdog Insider
    I like !!!!
    This is the first time I considered applying wheel stripes. It's a little "busy", but I eliminated a long section of white / gray fade to the right of the blue to help.
    I think it will look pretty cool.
  17. RogueRC24
    super nice!!
    "RC26-II" Upgrade Kit pretty much ready for install.
    CBR600F3 forks, wheel and fender. New Nissin Calipers. F3 rear wheel, 5.0" vs the F2 4.5".
    I have a new set of wheel spacers for the swap too and I'm working on a revised rear caliper bracket solution, so the parts that come off will be a complete kit.
  19. sixdog
    sixdog Insider
    Those wheels will make that bad boy look awesome Cap …
    It's gonna be weird at first.
