1986 VFR Restoreof Japanes import
Discussion in '1st & 2nd Generation 1983-1989' started by Thunderdome74, Jun 28, 2024.
  1. Thunderdome74
    Thunderdome74 New Member
    South Africa
    This is some awesome info guys, thank you so much!
    I have contacted some local guys regarding getting the viton O-rings, they have got a whole bunch of obscure stuff for me before, so lets hope ,before i contact Honda
    Forks, I was'nt going to take am apart, but might as well get rid of the antidive while i have the bike part
    Unfortunatly the costing on getting fork springs from the US is just going to be cost prohibitive at the momemt, we have a guy here thats well known for setting up and revalving front n rear shocks so might reach out to him
    The above info was really helpful
    The ECU
    (JDM Bike, assuming 77HP), i never really found a proper consensus of what and how its restricted.
    I've read if one replaces the ECU, the entire loom needs replacing?
    Then i read its govenerned by a green/pink wire on the clocks?
    I also read that the carb tops are restricted?
    and finally,I read that theres a half moon restrictor in the intakes (this i can definitivly throw out)
    Do you uys perhaps know for sure?
    #61
  2. Fastdruid
    Fastdruid New Member
    You don't need to replace the wiring loom. I'll dig the details out for you.
    WRT springs etc, use the racetech calculator to work out what you need, then get them locally. I did go with RT in mine but there is a UK distributor. You can get emulators from a few manufacturers (eg YSS), not all are as good as for example RT (because many have copied without understanding what they're doing and not bothered to account properly for differences in forks).... but still better than stock! Particularly so if you've got an expert who knows that brand and can set them up for you.
    #62
  3. Fastdruid
    Oh, I'd not heard about carb tops being different but I can't be absolutely positive they're not!
    #63
  4. Fastdruid
    So, the box to the right is the speed limiter. The one to the left is the ECU. Remove and bypass the speed limiter as follows. You can then also replace the "I" ECU with a "G" for full power.
    You can easily buy those connectors so you don't have to hack the wiring about and its then 100% reversible. This is an example of how someone has done it.
    It **NEEDS** to be an 86 year ECU though because the 86 is different to every other year of RC24, while you can fit a different year (even up to 97) that requires not only replacing or modifying the wiring loom but the tacho, fuel cut relay, pickups and the toothed wheel/starter clutch.
    #64
    Evan_VFR700F2H likes this.
  5. Fastdruid
    Restricted ECU
    Full power ECU
    #65
  6. Thunderdome74
    South Africa
    This is incredibly informative , thanks mate. So.....take a look at this
    If i am reading correctly...it looks like this one has bee modded (g). If so i will get a mate of mine to come look at the wiring...definetly not my strong suit
    #66
    Evan_VFR700F2H and Captain 80s like this.
  7. Thunderdome74
    South Africa
    Appreciate you digging out the details..i had searched this site and net to try find out but there were alot of guesses.
    #67
  8. Thunderdome74
    South Africa
    20240727_163448.jpg 20240727_105253.jpg 20240728_170648.jpg 20240728_164838.jpg 20240727_163448.jpg 20240727_105253.jpg 20240728_170648.jpg 20240728_164838.jpg Also got some more painting done today...again its not perfect but certainly better that what was before
    #68
    Fastdruid and Bazza like this.
  9. Thunderdome74
    South Africa
    20240730_192545.jpg So... onto cleaning the brake parts...all the pistons looked ok except fot this one...looks like somebody used a hammer and vice grips... i tried sanding it down but think its gonna be too much and wil leak
    Checking with honda if they have a new one
    Also checking a few breakers... is this quite a common item? Accross a few models?
    #69
    Front or rear piston?
    #70
  11. Thunderdome74
    South Africa
    Front
    #71
    Front piston part number "Where Used" for US models.
    45107-ML7-006 s/s to 45107-ML7-692
    Doesn't mean it was a front piston on all of these models tho.
    • CBR1000FA (87) 1000 HURRICANE, USA, VIN# 1HFSC210-HA001001 TO 1HFSC210-HA004655
    • CBR1000FA (88) HURRICANE 1000, USA, VIN# 1HFSC210-JA100001 TO 1HFSC210-JA100480
    • CBR1000FAC (87) 1000 HURRICANE, USA, VIN# 1HFSC211-HA001003 TO 1HFSC211-HA004975
    • CBR1000FAC (88) HURRICANE 1000, USA, VIN# 1HFSC211-JA100001 TO 1HFSC211-JA100722
    • GL1500A (88) GOLD WING, USA, VIN# 1HFSC220-JA000001 TO 1HFSC220-JA010467
    • GL1500A (89) GOLD WING, USA, VIN# 1HFSC220-KA100001 TO 1HFSC220-KA110411
    • GL1500A (90) GOLD WING, USA, VIN# 1HFSC220-LA200001 TO 1HFSC220-LA203608
    • GL1500AC (88) GOLD WING, USA, VIN# 1HFSC221-JA000001 TO 1HFSC221-JA001461
    • GL1500AC (89) GOLD WING, USA, VIN# 1HFSC221-KA100001 TO 1HFSC221-KA101412
    • GL1500AC (90) GOLD WING, USA, VIN# 1HFSC221-LA200001 TO 1HFSC221-LA200487
    • NX650A (88) MOTORCYCLE, JPN, VIN# JH2RD020-JK000005 TO JH2RD020-JK001565
    • NX650A (89) MOTORCYCLE, JPN, VIN# JH2RD020-KK100001
    • NX650AC (88) MOTORCYCLE, JPN, VIN# JH2RD021-JK000003 TO JH2RD021-JK000473
    • NX650AC (89) MOTORCYCLE, JPN, VIN# JH2RD021-KK100004
    • VFR700F2A (86) INTERCEPTOR, JPN, VIN# JH2RC262-GM000001 TO JH2RC262-GM001000
    • VFR700F2A (87) INTERCEPTOR, JPN, VIN# JH2RC262-HM100001 TO JH2RC262-HM101781
    • VFR700F2AC (86) INTERCEPTOR, JPN, VIN# JH2RC263-GM000001 TO JH2RC263-GM000500
    • VFR700F2AC (87) INTERCEPTOR, JPN, VIN# JH2RC263-HM100001 TO JH2RC263-HM100940
    • VFR700FA (86) INTERCEPTOR, JPN, VIN# JH2RC260-GM000003 TO JH2RC260-GM001826
    • VFR700FAC (86) INTERCEPTOR, JPN, VIN# JH2RC261-GM000002 TO JH2RC261-GM001036
    • VFR750FA (86) 750 INTERCEPTOR, JPN, VIN# JH2RC240-GM000008
    • VFR750FAC (86) 750 INTERCEPTOR, JPN, VIN# JH2RC241-GM000002
    Kind of a unique piston size.
    #72
    Bazza likes this.
  13. Thunderdome74
    South Africa
    Ok cool...so sounding like it should be readily availible. Thanks again
    #73
  14. Thunderdome74
    South Africa
    20240803_104440.jpg 20240803_133826.jpg 20240803_131131.jpg So managed to find another set of calipers...hopefully at least one of tbe pistons is good... rear heatshield was eaten through so i made another...hope the rear exhaust are seated properly... guess i will only know when i fire her up
    #74
  15. Thunderdome74
    South Africa
    A little concerned as I can't remember, but reading schematic it seems right... The right hand side swingarm bolt has 3x hat shaped washers to secure it... And the left hand side...nothing, just the frame?
    And the lower shock mount, a u shaped piece of steel...when I ran a bolt through it and tightened it to the alley pivot it didn't move, not quite seeing where Ive wrong....
    #75
  16. Thunderdome74
    South Africa
    20240804_145039.jpg 20240804_145034.jpg 20240804_145027.jpg 20240804_113426.jpg
    #76
    Always seemed odd to me that it does not have a needle bearing in that location, but it is correct. When you examine the linkage / shock movement, it doesn't need to pivot in that location.
    #77
  18. Thunderdome74
    South Africa
    understood, thanks Cap!
    #78
  19. Thunderdome74
    South Africa
    Hey Cap, hoping you can elaborate on disbling the anit dive? Is there w write up on explanantion anywhere (i have searched but not come up with anything) on diasbling the anti dive, might as well do it now at this stage, and go with your suggestion of 12 odd fork oil grade, I havn't ever messed with anti dive yet
    #79
    https://racetech.com/drod-5-2-honda-trac/
    #80
