1986 VFR Restoreof Japanes import
Discussion in '1st & 2nd Generation 1983-1989' started by Thunderdome74, Jun 28, 2024.
    155mm long. Little bit of camera effect on tape, verified. Height of "HONDA", black edge to black edge is 23mm.
    110mm total height. Top of my tape looks out of position... it is not. Camera effect and tape hovering a bit. I verified again conforming the tape to the tank.
    Wing position/length in relation to "HONDA"
  2. Thunderdome74
    Thunderdome74 New Member
    South Africa
    Thank you very much mate!Very appreciated!
  3. Thunderdome74
    South Africa
  4. Thunderdome74
    South Africa
    reckon this is close to Original, Thanks for the measurements Cap
    Captain 80s likes this.
    Much better.
    Final note: Centers of letters and spaces between are not "open", they are filled.
    But I suspect this is just for general layout and sizing, the painter will execute properly.
    Bazza likes this.
  6. Thunderdome74
    South Africa
    Illustrator_wQaDkpyKCh.png chrome_bqiYfSvdvw.jpg Ok, slowly getting there..
    Layouts done, subframe arrives so its on, and whoop whoop , the fuel pump is pumping and no longer leaking fuel
    Bazza likes this.
  7. Thunderdome74
    South Africa
    My eye is immediately drawn to the black border between the top of the D and A... It does not go straight across like your layout.
    The only place the border doesn't contour around letters, that isn't directly below the wing, is the top between the N and D.
    Where the black border of the wing meets the letters also needs a radiused transition.
    Bazza likes this.
  9. Thunderdome74
    South Africa
    Captain 80s, Fastdruid and Bazza like this.
  10. Thunderdome74
    South Africa
    Mate of mine did some printing
    Painter sent me a teaser...
    chuntera, Bazza and Captain 80s like this.
  11. Thunderdome74
    South Africa
  12. Thunderdome74
    South Africa
    For the life of me i cannot remember what this connects to (plug under the rivits)
    Everything else is together... igntion on and i get no pump noise and the start button does nothing.... solenoid?
    Mightbbe the battery is waaaay to low
  13. chuntera
    chuntera New Member
    Connecticut, USA
    #4 ignition coil ?
  14. Evan_VFR700F2H
    Evan_VFR700F2H New Member
    Denver, CO
    I assume you meant that yours is black & white, judging from your pictures. Upon examining the original document, it was mistranslated; it is supposed to say black & white (like yours), not yellow & white.
    Sent from my Pixel 7 Pro using Tapatalk
  15. Thunderdome74
    South Africa
    chrome_VxNK5bvcDA.jpg Ok, some news, she is turning over beautifully, New solenoid connected!
    Still can't figure out that thagt 2 pin plug by the rivit plate is for? I thought coils but they go straight into the loom.
    No fireing at all, even on a jerry tank, I suspect i havet the coil connectors wrong
    I put the colored wired to the green connector and the white and black to the black connector on the coils, but from what i can find this is wrong?
  16. Thunderdome74
    South Africa
    TX mate, I downloaded from somewhere the European wiring diagram, In german and italian but color designations seem right, will cross reference
    1986, correct?
    Cam Pulser (Cam Position), from the rear of the front head under the carbs.
    The location seems right and that would explain no firing.
    EDIT: Nah. Plug location seems wrong. Pretty sure that goes towards the battery along with the Pulse Generators.
  18. Thunderdome74
    South Africa
    Been futzing with the decals we got, complete rubbish, so annoyed by them:lynch:, even the fonts are wrong, so doing a mix and match to get as close as possible(bloody stickers were serious money to get delivered here )
    The painter has been fanstastic, I've been trying to get him fonts etc, he has also repaired the broken bits on mine, but he stays 100s of miles away so its a not just a matter of showing what is wrong
    My mate has the same bike and is doing his at the same time (will be chatting to him about where these wires go, and might get his help on the weekend if i dont come right
    (I'm useless with electrics)
    WhatsApp Image 2024-10-08 at 14.49.59 (1).jpeg WhatsApp Image 2024-10-08 at 15.51.06.jpeg IMG_5272highmount.jpg WhatsApp Image 2024-10-05 at 19.42.38.jpeg WhatsApp Image 2024-10-05 at 19.42.39.jpeg WhatsApp Image 2024-10-05 at 19.43.16.jpeg WhatsApp Image 2024-10-07 at 17.19.07.jpeg WhatsApp Image 2024-10-07 at 17.19.08.jpeg WhatsApp Image 2024-10-07 at 17.19.10.jpeg
  19. Captain 80s
    I can't stand when the font is off and it wasn't something I chose or bought off on. Sorry dude. Who did them?
  20. Thunderdome74
    South Africa
    Yeah, luckily my mate and i split the cost, So around $225 dollars each. Luckily the striping looks right so he will use it as a stencil and spray the whole lot
    I'll get the guys name, I didnt see it mentioned here...
