1990 Honda VFR 750F resurrection
Discussion in '3rd & 4th Generation 1990-1997' started by Pete.M, Jan 21, 2024.
  1. Totaled TL
    Totaled TL New Member
    Louisville, KY
    Would need to use micrometer and dial indicator to determine that. Pic isn't enough.
    #81
    you see grooves, right ?
    #82
  3. Pete.M
    Pete.M New Member
    Southeast PA
    Re the rear brake rotor, yeah it looks worse in the pics than in person, consequence of sanding it for paint. The grooves are not palpable so gonna run it as is.
    Well it's been a busy for me last few weeks with little time for the VFR. I took some time to reinstall the exhaust and fire it up and....
    She doesn't want to run. After a few tries I got it to settle into an idle but stalls if given any throttle and stalls without full choke. I checked everything over to make sure no stupid mistakes were made on re-assembly, and no intake leaks I could find. I know it ran after I cleaned the carbs like six months ago so carbs back off the bike.
    Yup, all the slow jets were clogged and there were black particles in the fuel I drained from the bowls.
    I checked and no debris coming from the tank (and there's a filter anyway)
    So it must be either the old fuel pump that shat itself sending debris up the line, or the new fuel pump or fuel line.
    I'm going to flush some fuel thru the lines using the fuel pump and see what comes out.
    #83
  4. squirrelman
    the filters should handle a little debris, right ? and its always best to run the carbs out of fuel then drain them b4 storage, every time so u dont need to waste time cleaning them later.
    #84
    Pete.M likes this.
    With today's fuel... ALWAYS drain the carbs for any kind of storage, like SM said.
    And not just run it til it dies. Actually drain the bowls.
    #85
    Pete.M likes this.
  6. Pete.M
    Pete.M New Member
    Southeast PA
    I could use some guidance here from the VFR carb gurus.
    After last week's problem (see previous) carbs are again cleaned and reinstalled. I ran about a pint of fuel thru the fuel pump into a container. I got three black specks of debris and then it looked clean. Reconnected fuel lines, cranked over until fuel made it to the bowls and she fired right up. Excellent!
    Now...
    I still can't get it to run unless choked, even after it's up to temp (verified on gauge and heard the cooling fan running).
    It will run at a fast idle about 1800 rpm on choke but doesn't sound right
    It stumbles and stalls if I back off choke
    stumbles and stalls if I rev it and let the throttle snap back
    It will rev, at first reluctantly but will hold 5000 rpm and sounds good there
    When I was warming it up, the #4 header was not nearly as hot as the others
    What I have done:
    checked there's no intake leaks, no kinks in fuel lines, fuel pump is working, verified fuel getting to bowl on #4, verified spark on #4
    valve clearances are good
    carbs are bench balanced only at this point- carb tune instructions say it needs to be warmed up and off choke to balance (but I hooked up the carb tune anyway, and 1,2,4 are quite close to each other while #3 reads a little higher than the rest
    Give it a listen. Bike is already at temp, but doesn't want to start. Got it to start with choke + throttle:
    https://photos.app.goo.gl/46Yh1A6h1HqueT3B6
    I am not touching any controls or making adjustments, idle is varying on its own
    https://photos.app.goo.gl/9GddzmQto6dZGAip6
    Ideas?
    Clean carbs again? WTF?
    Thanks in advance!
    #86
  7. squirrelman
    ^^ typical on carbs needing accurate synch and dialing-in of the mixture screws
    #87
    Pete.M likes this.
  8. Hingley
    Hingley New Member
    You may have a little carb balancing to do but the restore looks great, love seeing the optional clock, as a last note double check that you have no small air leaks like around the carb boots, mine was sucking air there after it warmed up and if reved the revs would hang up around 3000 for a few secs until it would settle down
    #88
    Pete.M likes this.
  9. Pete.M
    Pete.M New Member
    Southeast PA
    Update:
    This is what came out of the fuel line between pump and carb. Damn!
    So I pulled the carbs again and found the slow jets mostly clogged again! Thinking I needed to flush the system, I removed the bowls and float valves and set up a bath of clean fuel. Jumped the fuel pump and pushed fuel thru the carbs.... repeatedly. Filter on the pump inlet side so any debris "should" have got caught in the filter.
    After 5 mins or so I strained the fuel from the basin and got this:
    I did this 3 times and kept getting debris, so went ahead and disassembled the carbs again. Full clean, split the carbs, all tubes and lines looked good, no debris found.
    Now I need 2 new tiny cotter pins for carb reassembly. Little bastards snapped. Next weekend will be bench sync and reinstall carbs, new fuel filter and see if she'll run!
    #89
    bmart likes this.
  10. Pete.M
    Pete.M New Member
    Southeast PA
    Got the carbs re-re-reinstalled (how many cleanings is this now? I've lost count!)
    New fuel filter and new, better quality fuel hose. I'm throwing out the "Evil Energy" sh!t I bought on amazon.
    Started her up and right away I have a fuel leak under the #4 carb. So removed them again and found that I pinched the o-ring on the fuel tube where it enters #4 during re-assembly last week. Good thing I have extras. New o-ring, leak checked and all was well.
    Good news is I'm getting really good at cleaning and installing these carbs.
    And.... Woohoo sounds good!
    https://photos.app.goo.gl/QWMETNQDLLW8rZDP8
    #90
    RllwJoe likes this.
  11. squirrelman
    ........and u didnt think to leak-test the carbs b4 installing ? :homer:
    #91
  12. Pete.M
    Pete.M New Member
    Southeast PA
    Here's a tip for jumping out the fuel pump relay to test fuel pump or force it to run. Instead of making a jumper with 2 connectors and wire, I bent a fork connector so that it would slip into the terminals for black and blue.
    #92
  13. squirrelman
    sure, that looks safe and can handle whatever amps might pass thru, right ? :rolleyes:
    #93
  14. Pete.M
    Pete.M New Member
    Southeast PA
    Months ago when I pulled the centerstand bracket, some of the aluminum thread on the frame had fused to the steel bolts.
    Threads on the bolts cleaned up nicely with a die
    And threads in the frame
    Of course some of the threads are now missing, so I'll have to use some loctite and keep an eye on it.
    #94
  15. Pete.M
    Pete.M New Member
    Southeast PA
    The little surprises you find with an old bike....
    As I was reinstalling the gas tank I noticed some electrical tape. I've not known Honda to use electrical tape :(
    what's this? peel it off and found this
    No attempt at a proper fix, the PO just hooked one wire around the other and taped it up!!!
    That tape was old. I bought the bike in '97, so I know it's older than that.
    #95
  16. Pete.M
    Pete.M New Member
    Southeast PA
    Now that the carbs are balanced and pilot screws adjusted she's running great! Almost roadworthy.
    It was so much better using a carb adjustment tool to reach those balancing screws. Tight space in there!
    Does anyone know where this belongs on the bike? It looks like a shroud for the space forward of the battery box, around the starter relay?
    #96
    Correct. I actually left mine out on my 92. It just never looked like it was configured properly to fit right, I couldn't find any good reference diagrams or pics and I got tired of messing with it. But I also switched to a 94- battery box heat shield that extends out over the rear manifold, and the 94- doesn't have that extra rubber shield, so it's sitting in the "92 VFR" box.
    When you get it installed, please snap a pic.
    #97
    Pete.M likes this.
  18. Pete.M
    Pete.M New Member
    Southeast PA
    Thanks @Captain 80s yeah I got tired of messing with it too. Tried installing it every which way and it just won't fit right. If anyone else has one in place, I'd love to see a pic.
    #98
  19. Pete.M
    Pete.M New Member
    Southeast PA
    Well I've been busy riding and mountain biking and forgetting to post here! This is the best time to ride.
    Still making progress here and there on the VFR. Got the chain installed and some little things buttoned up. I've been working on the many small repairs of the plastics. Lots of little cracks and problems. Both sides of the front turn signals were cracked at the mounting tabs and the stud that hold the nut insert. Glued them up and made an abs patch for extra support on the tab, glued that over top. A lot of little stuff like that.
    #99
  20. Pete.M
    Pete.M New Member
    Southeast PA
    Today I messed around with soda blasting the alum parts. Worked out great! Made quite a mess but it's safe and cleans up easily with the leaf blower :)
    Here are some comparisons of the pieces scrubbed, unblasted vs in progress blasting
    This was done with an old budget Sears Craftsman sand blasting setup and a good sized compressor at 85psi. So much faster than using scotchbrite and sandpaper!
