1990 VTR250
Discussion in '1st & 2nd Generation 1983-1989' started by Captain 80s, Feb 15, 2025.
    someone that doesn't want to have an old oven on the side of their shop tip:
    Hang the painted exhaust pieces (typically how I paint them anyway) and pre-cure the coating using a propane torch thru all of the inlets and outlets. Keep in one opening until that area starts smoking off, go a bit longer, and then move to another one. Rotate around doing each one a couple times.
    Greatly improves the durability for handing and mounting and has proven to be a very good first step for longevity. Plus helps protect against chemicals during the initial install and replenish of fluids in the area.
    RogueRC24, sixdog and Bazza like this.
  2. RogueRC24
    You lucky B! I wanna jump in and paddle around now.. shame on you! hahahaha
    Bazza likes this.
  3. sixdog
    sixdog Insider
    No Ka Oi Brah !!!! One thing is most riders here are not wearing helmets and they are wearing slaps ( sandals ) while riding!!!!! INSANE!!!!!
  4. RogueRC24
    I remember dudes wearing slippahs on there xr250s. No thank u.
    I REALLY didn't want to go this far. Slide the forks out, hang the shit to replace the steering bearings (cuz, I'm f-ing here).
    Well... the bike had 3 different keys. And the custom 88 I'm building had the original matching 5K mile gear. So swap that over. The 88 doesn't have seat latch/helmet lock anyway. I might not even use an ignition switch, so gas cap only stored on the bike. Or a double sided key at worst. FINE.
    And then I looked at the choke cable that needed attention. OK, that comes apart. The paint job I did on the clip-ons for my Sis years ago was looking a little haggard... well... I could freshen those up and the clutch perch. FUCK!!
    The plan was to disassemble the forks tonite. Not feelin' it now. Dinner time. Tired AF anyway, long week.
  6. sixdog
    sixdog Insider
    Dude … live to fight another day.
    Rest up my brother
  7. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Looking good, Capt.
    Just remember. It's not the destination that counts. It's the journey!
    And one of the challenges in mechanical work is knowing when it's time to set everything aside and take a break.
    You followed your instincts and did good!
    And now when you come back to it - things will look much better! :)
    Wife is going to her Parent's place Sat and Sun. Gonna be rainy around here, so I'm looking forward to some quality shop time to make some progress.
  9. Bazza
    Bazza Member
    Sounds like a good time for a party! :D
    Hell yeah. Maybe I'll also find a radiator to straighten all of the fins with a tiny flat blade.
  11. Bazza
    Bazza Member
    LOL....
    FINALLY got the front forks apart for the YSS PD Valves (Emulators). Bushings look brand new, as do the dust seals. Weren't leaking, but new oil seals going in. Oil looked very fresh too. Pretty sure I went thru thru the forks for my sister years ago when she got it.
    Good news: Perfect fit with the damper rods
    Unexpected news: Rods only have 1 set of holes. "Get to" drill 8 new holes.
    bmart and Bazza like this.
    Sandblasted and painted some front end hardware. Had an extra front cowl stay that I eliminated the front turn signal mounts as I won't be needing them.
    Also used an extra side stand to eliminate the rubber mount and boot loop. With the rearset adapters the loop was fairly inaccessible under the footpeg anyway. Plus cleaner looking.
    Bazza and RogueRC24 like this.
  14. Terry Smith
    Drilling holes is all part of the fun with emulators Mike. I recall I had to do 6 x 8mm holes on my 86 VFR forks?
    Bazza likes this.
    Yeah I know. This is probably my 8th set of Emulators, 2nd set of YSS PD Valves. Still have YSS PD to install in the 86 VFR700FII (getting 41mm RC24-II forks), and the VT250R Custom with 86 VFR forks.
    The very first time I've come across damper rods with only 2 holes. All of my other other Hondas had 2 sets, 4 holes, @ 8mm already.
    YSS definitely plagiarized the RT instructions.
  16. Terry Smith
    Plagiarism is the sincerest form of flattery.
    RogueRC24 and Captain 80s like this.
    Rods drilled, 4 new holes each @ 8mm.
    Forks back together... Finally. New oil seals, the bushings looked almost new. Inspected and dressed the tubes with ~1000, then polished them back in. They always had some pitting around the lower clamp, but the oil seals I put in years ago were still good.
    PD Valves @ 4 of 7 turns in. 15 wt @ 135mm. RT suggestion was 140, but I didn't do springs. The stock front end was surprisingly good, so going with this for now. Adjustable preload caps on the way, just for looks, and I'll dial in the spacers then.
    The required, ever-important and accurate, off-the-bike compression/rebound test felt as expected.
    RogueRC24, Bazza and bmart like this.
  18. RogueRC24
    I should have gone with 15wt. I just used the rest of the 10wt but she is squishy. Either way I will pay more attention. Your getting there!! Nice work.
  19. bmart
    bmart Member
    Charlotte, NC
    15W was always the best in my 1990 VTR250.
    Well, this is for the rebound with the Emulators.
    I'm surprised 15 wasn't a bit harsh with the stock damping rods with only 2 holes. I tend to not go heavier than 12.5 with stock damper rods. But that is becoming a concern of the past, I only have 2 bikes that are still stock damper forks. The 86 VFR700FII that I already have the parts for and my 86 VF500F that needs to be gone thru anyway.
