1990750f battery drain issue
Discussion in '3rd & 4th Generation 1990-1997' started by vfreak750, Jul 12, 2012.
  1. vfreak750
    vfreak750 New Member
    ONTARIO
    My VIFFER was diagnosed twice by two separate shops. The latest one is from a Honda service center. Both instances recommended to replace the battery. All diagnostics showed that it was charging properly (shop indoor tested). For some reason after a long period of riding (approx 10-12 hrs) it just kills the battery. I'm taking it back again tomorrow to Honda, but I'm hoping to hear from someone in this thread if they've experienced the same issue. I don't want to give up on this bike as what my other rider volunteers (running a charity group) advised. I'd like to achieve its iconic figure of long distance capability. Please help? thanks
  2. kennybobby
    kennybobby New Member
    Ask them to replace the Rectifier/Regulator unit in addition to the new battery, and to carefully inspect the connectors, wires and crimp lugs for any evidence of overheating and burning. This is a very common failure on these bikes. If you use the search function you can read a multitude of stories about failure of the RR and the anguish, fear and loathing that it causes to both owners and mechanics.
  3. vfreak750
    ONTARIO
    thx for your input...I've arranged that with the dealership now
  4. squirrelman
    Service manual shows how to test for reverse current flow from battery with key off. Any current leakage suggests a bad r/r.
  5. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    You really need to conduct the charging tests after the bike has been ridden for a while and is really good and warmed up since faulty electrical components tend to fail when they get really hot. Simply starting the bike up and testing after sitting a while can give false readings which is exactly what happened when I was troubleshooting my charging system the first time it was giving me problems.
    Rollin
