1991 VFR 750 Cranks but No Start
Discussion in 'Mechanics Garage' started by Kintama, Jul 25, 2026.
  1. squirrelman
    I’d try blowing low-pressure air (lungs) into the fuel line, first. Listen for air flow.
  2. ridervfr
    Sounds suss, you running a nurse bottle? no carb synch was spoken about.
  3. squirrelman
    hey, warren !! i would consider bad synch among the lowest-likely probable causes o_Oo_O
  4. ridervfr
    Could be wildly out of synch Jerry, just some food for thought, I know it comes into play a CH off the throttle and once the bike is on the mains its out of the equation.
  5. Kintama
    Kintama New Member
    Two of the float valves are stuck to their respective float bodies. I believe the assembly number is: 16011-MT4-000. Looks like $40 each, if I can find them. Any hints?
  6. ridervfr
    upload_2026-8-2_20-8-58.png looks like they are 52.68 - Honda knows how to charge, I bought a fuel line I thought I could not get anymore.
  7. squirrelman
    thats why i suggested air pressure, to push the needles off their seats----u prob dont need to buy anything, just get in there and inspect float n eedles for deterioration -----clean the n eedle seats with q-tips wetted with solven t-----what u describe is so uncommon that your analysis is likely wrong---also, dont store vfr carbs upside- down----
    Thumbs likes this.
  8. Thumbs
    Thumbs Member
    Bath(ish)
    Great idea, thank you sir
  9. Kintama
    Kintama New Member
    They were definitely stuck. I soaked them in a jar of Rocket Chemical Company's finest, but they wouldn't budge. I replaced them, and now have fuel in all 4 float bowls. Now it won't crank. Battery seems to be good, and it's fairly new, so I donno, what's next?
  10. squirrelman
    i guess it never stops, eh ? :Cry:-----recharge battery to at least 12,6 volts and try again---check fuses and neutral switch--
  11. Kintama
    Kintama New Member
    Well, I guess the starter was just "stuck". Once it decided to crank, it stared right up. Guess what I'll be doing this weekend.
    RllwJoe likes this.
  12. Kintama
    Kintama New Member
    OK, it starts every time now, but the idle is really erratic. I'll start it with choke and it will immediately go to 4000 rpm. Pull the choke off and it stays there. Adjust the idle speed knob all the way down, eventually it goes down. Then it keeps going down. Adjust the idle speed knob all the way and eventually it dies. Any ideas?
