1991 VFR 750 Starts and Runs but won't hold Idle
Discussion in 'Mechanics Garage' started by Kintama, Aug 6, 2024.
  1. Kintama
    Kintama New Member
    Any ideas what to try? I get it started, hold it at 3 or 4000 RPMs for a few minutes and it sounds fine, but when I let go of the throttle it just slows down and eventually stops within a minute or so. New battery, good gas, cleaned out the carbs a few years ago.
  2. jethro
    jethro New Member
    Parkville, Mo.
    Carbs. Unless you are using no ethanol fuel which makes a big difference in carb cleanliness.
  3. Kintama
    Kintama New Member
    Do you recommend a carb rebuild kit? If so, which one? Or is it enough to take the carbs apart and clean them?
  4. jethro
    jethro New Member
    Parkville, Mo.
    I would be real careful and try and reuse the stock stuff if they look ok. Give everything a good cleaning and pay particular attention to the pilot jets and passages.
  5. squirrelman
    idle jets arent clean, probably all thats wrong. if u left gas in carbs during storage (instead of draining bowls) its very likely the idle jets are clogged.
