1994 RVF400R Build Project
Discussion in 'Mechanics Garage' started by NorcalBoy, Nov 7, 2018.
  1. NorcalBoy
    Speaking of patience, I pinged Braketech about the Axis Iron rotors and they still haven't gotten the blanks back from the grinder....looking now like September, at the earliest. I am going to have the zen of a Buddhist monk by the time this ends. :Playball:
  2. Gator
    Gator Member
    Its funny, the longer the project takes the more jacked up you get when it's close to the finish line. That first ride is always fun.
  3. squirrelman
    i've always done that on all my Hondas as SOP, especially important after an oil change.
  4. Diving Pete
    Sounds like a sensible idea to me. It looks as if COVID has really put everything back a year....
  5. NorcalBoy
    Went by the shop as soon as I flew into town this morning. The moto is broken in and it's done a couple dyno pulls to 14k RPM. It's looking like it needs some new needles for the carbs. The OEM needles I have, J8VA's, are the wrong taper and it's a tad too fat between 4.5k and 6.5 k. The initial numbers, with no tuning, are 68-69 hp. My boys are estimating mid to possible high 70's after tuning. Have an email into Rick Oliver in the UK to see if I can source some new needles. I hope he gets back to me soon. I'm looking to get a set of 8's - A's, B's, and C's, as well as, a full suite of 9's in the A, B, and C taper.
    Jim McCulloch likes this.
  6. KarlR
    KarlR New Member
    Esopus, NY
    Wow, that is screaming.
    I understand the different jets and what they do, but I have no clue about the needles. What part of the fueling do they affect?
  7. NorcalBoy
  8. Jim McCulloch
    Jim McCulloch Member
    Wow you can see why they went to fuel injection now.
    That is some voodoo shit right there. One would need meticulous records to map all that out regarding what did/did not work.
  9. NorcalBoy
    I was able to source a replica HRC jet kit from Rick Oliver in the UK. He is going to be drop shipping the kit to my tuner. This kit was discontinued by Honda, but Rick has assembled all the pieces to put it together. There are a couple companies stateside showing the Honda part available, but they are asking between $250 and $350 for them, and I doubt they even have them. Rick has his kit available for $179 and I've worked a lot with Rick in the past, so I'm going with the guy I can trust.....Rick.
    NC35 HRC replica carburetor kit £130
    Equivalent to Honda part# 06160-NKA-900 and consists of -
    4 - J9MA needles
    4- J9MB needles
    4 - J9MC needles
    12 - Needle circlips
    4 - 0.5mm needle shims
    4 - Emulsion tubes
    4 - Slide springs
    2 - HRC replica 30mm velocity stacks
    I already have the needle shims in 0.5 and 1.00 mm, HRC springs, and replica stacks, so these will be extra stock. I'm hoping the rest will be enough to get the job done.
  10. NorcalBoy
    It's actually not that difficult and it's made a lot easier with the dyno having an exhaust sampling channel and sensor. By the charts, it was very obvious where the issue was. Getting the right pieces was/is the hardest part of it.
  11. Gator
    Gator Member
    What’s the average time to swap out carb components? Once you’ve done it a few times I imagine you’re pretty quick at it. How accessible are the carbs?
  12. Diving Pete
    They are under the airbox - LOL
    Basically in exactly the same place as the VFR800
    Gator likes this.
  13. Diving Pete
    It depends on how quick and dirty you want to do it & what job you need to do on the carbs. You don't have the tank connected as you are running a external one & no fairings are in the way, its just a matter of disconnect the fuel, undo the 4 cross heads (JIC 2) on the intake rubbers and lift off.
    However, most people will also disconnect the throttle cables using 2 x 10mm spanners, maybe the choke cable if connected (JIC 2) cross head, and also possibly the airbox - also if installed.
    Now I can't remember if you have to remove the airbox base to get to the top screw but that's only 8 x JIC 4 cross heads and lift off.
    Then its remove the 3 x JIC 2 crossheads per carb, slowly remove the top, ensuring the vacuum spring doesn't go into orbit, and then withdraw the vacuum assembly complete. Change what you need to then reassemble.
    Not difficult, and as long as you have newish 'lubed' intake rubbers fairly quick.
    To do the bottom of the carb (main & pilot Jets) is easier & doesn't involve airbox removal.
    Gator likes this.
  14. NorcalBoy
    I have no idea how long it takes, but the slides were already out of it when I arrived. If it was me, and everything was set up, maybe 30 mins to do all the bottom brass and prolly the same to do all 4 needles. I remove the rubber locators off of the insulators and index the clamps to make it easier to pull the carbs.
    It didn't look like they had disconnected anything, except the choke cable. Of course, the airbox and tank were removed, both easy tasks. I have a quick disconnect on the fuel line and the fairings aren't installed. I took it to them sans fairings, just the tank and the seat. It looked like they had been running it off an aux fuel bottle on the dyno.
    Gator likes this.
  15. Gator
    Gator Member
    Thanks for the info. The only bike I have left that has a carburetor is a Suzuki DR 650. I sold my Yamaha RD 350 a few years back. Both those bikes are pretty easy to work on the carbs.
  16. NorcalBoy
    No problem, thanks for the questions. I try to always reassemble things to make them easier to work on later. Building them on an assembly line and working on them later, are two completely different things. These V4's have a lot of things crammed into a very small space, so everything you can do to help yourself out is worth it.
    Gator likes this.
  17. Diving Pete
    The indexing of the carb rubbers is almost essential to getting it back together quickly. I refit all cables before mounting as its just easier - although it is possible to do it on the bike. As mentioned there isn't much space & what you don't want to do is go backwards
    Gator likes this.
  18. KarlR
    KarlR New Member
    Esopus, NY
    Thanks for the diagram. Looks like the needles are the most important part of the tuneing.
  19. NorcalBoy
    They have the most effect in overall range. The issue with CV carbs is that the needles are typically not adjustable, they look like a nail. The new needles in the HRC replica kit have 2mm of up and down adjustment with moveable clips, so that is a positive benefit. Allows for finer adjustments, after that, it's shims to get it even closer. Most jetting info people have is from close to sea level, here in the pueblo it's 2650'. Once again, it's a science experiment and knowledge gathering quest.
  20. squirrelman
    too simplistic. other major factors are venturi size and main jet size.
