1998 to 2001 engine swap
Discussion in '5th Generation 1998-2001' started by stevoz, Apr 21, 2020.
  1. stevoz
    stevoz New Member
    Hi everyone, I’m new to the forum. Would like some advice. I’ve got a 98 model and looking at an engine swap with a 2001. As far as I can see pretty much all the engine part numbers are the same. My only concern is the electrical side of it. But I’ll use my existing harness and throttle bodies. Any help would be great cheers.
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    Maybe someone else knows better, but the only real difference is the wax motor for the starter valves... you taking your existing '98 TB's will keep everything the same.... rock on!
  3. mello dude
    Romania
    Should be a simple job, especially if you are using the '98 TBs and electrics.
  4. stevoz
    stevoz New Member
    I’ll go ahead with it and let everybody know how I go. Cheers
    zer0focus likes this.
