1999 wont rev, 5 days to fix it
Discussion in 'Mechanics Garage' started by wiso, May 10, 2020.
  1. wiso
    wiso New Member
    upstate NY
    1999, starts with no "chock" lever. idles at 1000, if I give it throttle it wont rev past 2 or 3k. I can play with throttle and eventually gate it to rev reluctantly past 5k, but it takes some twisting. I'm going on a trip in 5 days, I need this bike.
    I verified electrical system. Has new battery, thermostat, fuel filter, plugs, injectors, air filter, valves just adjusted. I adjusted the starter valves once. not after injector replacement.
    Parts replaced due to previous owners neglect of the bike.
    I'm thinking I have to reset starter valves.
  2. RllwJoe
    RllwJoe Insider
    When you adjusted the valves did you need to remove/ replace any of the shims? If so I wonder if the valve timing could be slightly off.
  3. wiso
    wiso New Member
    upstate NY
    Yes I did replace shims, but it ran same way before the valves were done.
  4. squirrelman
    i'd suspect the fuel pump might have low pressure.
  5. Terry Smith
    New Zealand
    Are you seeing any fault codes flashing (the FI light)? I recall once leaving the hose off the MAP sensor on the back of the airbox and it ran but not well, and I had the fault codes flashing to tell me of my mistake.
    NorcalBoy likes this.
  6. wiso
    wiso New Member
    upstate NY
    No fault codes, once I get it to go past 6k it revs right out fine.
  7. Terry Smith
    New Zealand
    No fault codes means the FI system believes all the measurements/instruments are OK so that rules out quite a bit.
    You don't mention spark plugs, but for the cost of some replacements I'd change those out just to eliminate them as a possible fault. Another possibility is the fuel pressure regulator, this is connected to intake vacuum and drops the injection pressure when the intake vacuum is high (so the relative injection pressure stays the same as intake conditions change). A leaking or disconnected hose would give you a rich mixture at low revs/high vacuum.
  8. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    Mouse nest?
  9. squirrelman
    oh, sure, blame a rodent !
  10. GreginDenver
    Denver, Colorado
  11. RllwJoe
    RllwJoe Insider
    New filter....but how long ago was it installed?
  12. wiso
    wiso New Member
    upstate NY
    Air filter, plugs, thermostat, clutch plates, clutch slave , oil, all new
  13. wiso
    wiso New Member
    upstate NY
    So this Starter sync procedure. The first time I set them they were all way out. Now I started with them all in and with little adjustment they are all balanced. Also the bike will idle at 1200 with the idle set screw all the way in only.
  14. wiso
    wiso New Member
    upstate NY
    Tomorrow I have a coil, air temp sensor, and MAP sensor arriving.
  15. wiso
    wiso New Member
    upstate NY
    The guys who are going with me on vacation have offered to lend me a bike for the trip, im having a hard time with that.
  16. wiso
    wiso New Member
    upstate NY
    Found the timing is off about 15degrees.
  17. squirrelman
    OMG who worked on ur bike ? lucki no bend vlves.
  18. wiso
    wiso New Member
    upstate NY
    not valve timing, ignition timing.
  19. squirrelman
    never herd b4
  20. wiso
    wiso New Member
    upstate NY
    Service manual tells how to check it with timing light.
