1999 wont rev, 5 days to fix it
Discussion in 'Mechanics Garage' started by wiso, May 10, 2020.
  1. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    Now you've got my curiosity up.
    Most VFR owners are completely unfamiliar with the parameters of the bike's Ignition System. We (VFR owners) simply make sure the items related to the Ignition System are installed in the correct manner.
    And if I remember correctly, none of the performance add-on boxes (Rapid Bike or Power Commander) have the capability to change/adjust ignition timing.
    So I'm guessing that your 5th Gen doesn't have anything added onto it (no special performance boxes) that would be adjusting/changing the ignition timing (in other words, nothing is messing with the number of degrees BTDC, before top dead center).
    So if nothing has been added to the bike I would have to imagine that a messed up ignition timing would be the result of a malfunctioning input parameter to the Honda PGM-FI ECU. And the best candidate for that would be the Throttle Position Sensor. Or a grounding problem (poor path-to-ground somewhere).
  2. GreginDenver
    Denver, Colorado
    I say all of that because a 15 degree change in Ignition Timing isn't that much. On a modern, ECU controlled engine when you roll hard onto the throttle the ignition timing will be changed/manipulated by the ECU.
  3. wiso
    wiso New Member
    upstate NY
    No other add ons installed. The ignition does advance as the rpms increase. I'm not sure the TPS effects timing. I think it just locates throttle plates so ECU can adjust fuel delivery.
    The pulse generator triggers the ECU to the position of the crank.
  4. wiso
    wiso New Member
    upstate NY
    I have another ECU and pulse generator on the way..
  5. wiso
    wiso New Member
    upstate NY
    I had the best mechanic I know go through the bike to verify everything and diagnose the issue.
    The previous owner was messing around with the electrical system due to charging issue, I think he may have damaged the ECU with his "advanced" electrical skills.
  6. GreginDenver
    Denver, Colorado
    Oh really? You're sitting there looking at the Service Manual, in chapter 17, the chapter that talks about the ignition system, with diagrams that clearly show the input parameters related to the Honda PGM-FI ECU's ignition control function, and "you're not sure" that the Throttle Position Sensor has anything to do with ignition?
    Okay, I'm out of this thread.
  7. wiso
    wiso New Member
    upstate NY
  8. wiso
    wiso New Member
    upstate NY
    If the TPS was bad, wouldn't it throw a error code?
  9. wiso
    wiso New Member
    upstate NY
    If you reread my post, I said I wasn't sure the TPS effects timing. The TPS does in fact just locate the throttle plates for the ECU.
    Section 21-14 and 21-15 describe what the TP and IPG do.
  10. wiso
    wiso New Member
    upstate NY
    Just because the ECU gets data from a sensor, doesn't mean that it is used to control the timing.
  11. wiso
    wiso New Member
    upstate NY
    And, chapter 17 has no parameters in it at all about the ignition system.
    Glad you are "out of this thread"
  12. squirrelman
    CDI no good.
  13. raYzerman
    raYzerman Member
    Millgrove, ON
    Throttle position info is a necessary component for ignition timing. If the ECU doesn't know where the throttle is, how would it know when and where to adjust timing....... as you said, timing advances as rpm increases, which only occurs if the throttle plates move.
  14. wiso
    wiso New Member
    upstate NY
    RPM is not provided by the TPS.
  15. raYzerman
    raYzerman Member
    Millgrove, ON
    RPM is provided by your right wrist, TPS tells the ECU where it is that produced that RPM.
  16. wiso
    wiso New Member
    upstate NY
    I meant that the ECU doesn't get the info on RPM from the TPS. The ignition advances from RPM increase, not throttle position. The RPM is read by the Pulse pickup at the crank.
  17. raYzerman
    raYzerman Member
    Millgrove, ON
    Just for your info.... a faulty TPS can cause many issues... may not be your problem, but you'll find out eventually. Here is a Yamaha one that was faulty, though it appears great to the naked eye. The four-fingered wipers ride on a ceramic resistor board with two paths of variable resistance, ECU interprets that signalling. Honda TPS should be somewhat similar, but I never dissected one.
  18. wiso
    wiso New Member
    upstate NY
    Thanks for the info, Itcant hurt to test mine to be sure.
  19. wiso
    wiso New Member
    upstate NY
    Honda test procedure requires a plug in box to check voltages from TPS. Which I do not have access to. So replacement is the option.
  20. wiso
    wiso New Member
    upstate NY
    replaced TPS, ECU, pulse generator, cam sensor, timing is still off around 10degrees
