Hi there. I have two Tourmaster Synergy vests. I was wondering if I would melt something down or burn down something if I use both of them on the same bike? Its documentation says it can pull up to 75 watts.. Many thanks, -t
I would go through and clean up your charging system connections to be sure you've got a reliable system. Not sure about 2 vests Sent from my SM-N950U using Tapatalk
Bike should be able to handle it. Bearing mind that they prob won’t be on full all the time. Make sure they are wired in via a relay tho.
