2000 vfr - high idle at temperature ??
Discussion in '5th Generation 1998-2001' started by sdgman, Jun 4, 2011.
  1. 01VFRNorth
    01VFRNorth New Member
    Muskoka
    what is BB troll Wax Idle Unit...? (yes I'm new..ish)
  2. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    Don't mind him, sunofwolf is our site troll :crazy:
    Check for a vacuum leak. Prop the tank up, fire her up, and lightly spray carb cleaner around the throttle body base (gasket bad) and hoses (cracked) or unhooked and see if engine speed changes any.
  3. BlueGrowler
    BlueGrowler New Member
    Tasmania, Australia
    Got exactly the same problem 2001 model. Only happened since doing Pair Removal
    Cold idle fine. Hot idle 2500rpm. Guess I'll try the hot idle screw first. Maybe I shifted it when doing the PAIR...
  4. AtHomeOn2Wheels
    AtHomeOn2Wheels New Member
    I drained and flushed my rads. Then took off the breather box pulled the hoses off the wax unit cleaned the wax unit fluid resivoir fluid and tested with a hair dryer. Fixed my problem.
    I had the same things happening too.
    Fixed it right up.
  5. AtHomeOn2Wheels
    What is the benefit of pair removal?
  6. Terry Smith
    The PAIR system bleeds some fresh air from the airbox into the exhaust port to aid destruction of unburnt hydrocarbons to assist in meeting air emission limits. Removal of the PAIR system gets rid of quite a bit of surplus plumbing that makes for easier maintenance, but does nothing for performance. Some have reported that it reduces popping on deceleration (which sounds plausible) and others that it improves part-throttle running on bikes equipped with an O2 sensor (which also sounds plausible). On my 99 it did nothing but remove weight and hoses.
  7. BlueGrowler
    Tasmania, Australia
    Ok so lifted the tank turned the hot idle screw anti clockwise... no change.
    It seems that the *metal thing* that pushes on the screw gets stuck. IE theres
    an inconvenient gap between it and the screw.
    Is this the replace the "fast idle wax unit" part problem or am I going to get lucky with some
    well placed lube?
  8. AtHomeOn2Wheels
    I had the exact same problem.
    Step 1.
    Drain antifreeze.
    Step 2 .
    Mix distilled water and white vinegar 50/50
    Step 3.
    Fill rads and run bike for 10 to 15 min revving the throttle to high RPMs off and on throughout the 10 to 15 min.
    Step 4.
    Allow bike to cool then drain coolant.
    This will conclude the rad flush.
    Then remove the breather box. Remove the hoses and cap on the kick stand side of the wax seal unit. Clean the bowl and make sure antifreeze is flowing into the bowl. Get a portable heat source. Test the wax seal unit to verify the wax unit is functioning appropriately.
    PM with any questions.
    This fix didnt cost me a dime, just time.
  9. highsider989
    highsider989 New Member
    ALexandria, VA.
    all:
    After replacing my thermostat and hoses I has the same issue. On another forum someone recomended spraying the starter valve linkages with WD-40. Super easy to do and it worked!! 2000 rpm during warm up and 1200 hot.
  10. Knight
    Knight New Member
    USA
    I am glad you solved it, great news.
  11. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    This high idle does seem to be a symptom of sticky start valves and a wax unit perhaps adjusted a wee bit high.
    Check this sticky situation out...
    You can see the filth in the air bypass ports and the upper valve is stuck almost wide open! Yah she ran but it wasn't pretty. A good clean an lube of the valves as well as a sync sorted it all out.
  12. sunofwolf
    sunofwolf New Member
    this might be whats wrong with my low idle
