2002-06 Honda Interceptor
Discussion in 'Specifications' started by michael, Jun 14, 2006.
  1. michael
    michael Administrator Staff Member
    Kihei, Maui, Hawaii
    2002-2006 Honda Interceptor
    Model: 2002-06 Honda Interceptor
    ENGINE
    Type: 781 cc, V4, 4-stroke
    Cooling: Liquid
    Bore x Stroke: 72.0 x 48.0 mm (2.8 x 1.9 inches)
    Max HP: 80 kWa (108 hp) @ 10,500 RPM
    Torque: 80 Nm (59 ft-lb) @ 8750 RPM
    Compression Ratio: 11.6:1
    Transmission: 6 speed
    CHASSIS
    Front suspension: 43.0mm HMAS cartridge fork with spring-preload adjustability; 4.3-inch travel
    Rear suspension: Pro Arm single-side swingarm with Pro-Link single HMAS gas-charged shock with seven-position spring-preload and rebound-damping adjustability; 4.7-inch travel
    Front brake: Dual full-floating 296.0mm discs with LBS three-piston calipers
    Rear brake: Single 256.0mm disc with LBS three-piston caliper (ABS model has Anti-Lock Braking System)
    Front wheel: 3.50 x 17 in.; cast-aluminum
    Rear wheel: 5.50 x 17 in.; cast aluminum
    Front tire: 120/70 ZR-17 Dunlop D204 Sportmax radial
    Rear tire: 180/55 ZR-17 Dunlop D204 Sportmax radial
    Rake: 25.5 degrees (2002-2005), 25.3 degrees (2006)
    Trail: 95mm (2002-2005), 100mm (2006)
    Wheelbase: 57.4 in. (1458mm)
    Length: 212 cm (83.5 in)
    Width: 73.5 cm (28.9 in)
    Height: 120 cm (47.2 in)
    Seat height: 31.7 in. (805mm)
    Fuel capacity: 5.8 gal. (22L), including 0.8 gallon reserve
    Dry Weight: 481 lb.
    Instruments: Digital LCD speedometer, tachometer, readout for coolant temp, outside ambient temp, fuel level, clock, odometer, dual tripmeter, lights for neutral, high beam, turn signal, low oil pressure, fuel injection problem
    PERFORMANCE
    Fuel consumption: 34 to 43 mpg, 36 mpg avg.
    Quarter-mile: 11.22 sec. @ 119.80 mph
    Roll-ons, 6th gear: 60-80mph/5.26 sec., 80-100mph/5.82 sec.
    AVAILABLE COLORS
    2006: Pearl White, Pearl Black
    2005: Light Silver Metallic, Red
    2004: Asphalt, Red
    2003: Metallic Silver, Red
    2002: Red
    DESCRIPTION
    For 2002, Honda recreated the Interceptor bit by bit, incorporating improvements into every facet while retaining the essential foundations. As a result, the VTEC(TM)-equipped Interceptor is now a markedly advanced, new-generation sport bike, and arguably the sharpest-edged street-going iteration yet. At the same time, Honda's engineers also reconfigured the Interceptor so it could accept a set of Honda-designed accessories--including hard saddlebags--to create a top-rank sport bike with true cross-country abilities.
    <a href="http://vfrworld.com/photos/showgallery.php/cat/503" target="_top">VFRworld Photos of the 2002-2009 Honda Interceptor</a>
    <a href="http://vfrworld.com/forums/sixth-generation-2002-2009/" target="_top">VFRworld Sixth Generation Forums</a>
    <a href="http://vfrworld.com/forums/parts-service-manuals/3161-downloadable-parts-catalogs-service-manuals.html" target="_top">Downloadable Service Manual</a>
