2006 VFR800 Died on first night ride...
Discussion in 'Mechanics Garage' started by blackvfr, Jul 25, 2016.
  1. blackvfr
    blackvfr New Member
    Connecticut
    Not sure what they where to. I'm sure one was the fuel pump and the other I don't know because I didn't follow the wires. One was a black fuse holder and the other was white with a cover.
    Sent from my SM-N910T using Tapatalk
  2. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Was the white one under the seat?? Near the starter relay??
    Sent from my A0001 using Tapatalk
  3. blackvfr
    blackvfr New Member
    Connecticut
    Yes it was under the seat, both fuses where under the seat...
  4. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    So the one fuse was for your starter relay and the other the main fuse.
    Definitely do the drill.
    Send photos of those connectors and wiring at the connectors
  5. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I thought the main fuse was 30amps?
    Sent from my Nexus 6 using Tapatalk
  6. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Hmm. Good point.
  7. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Maybe that's the problem lol. Toss in a 30amp and be done. If only it were that easy.
  8. Glenngt750
    Glenngt750 New Member
    Edmonton, Alberta, Canada
    He IS kidding about the 30 amp fuse!!! Do not replace your 20 with a 30 amp fuse, unless it is supposed to be a 30 amp. Make sure you find out why it blew, and WHAT it blew. No guessing or supposing allowed!
  9. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    The main fuse is 30 amps....
  10. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Pretty sure its supposed to be a 30A
  11. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I'm still waiting for blackvfr to say what fuses it was.
  12. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    It would be nice if the OP decided to stop back in with some pictures of the two fuses that popped....
    Hint hint wink wink
    :worthless:
  13. blackvfr
    blackvfr New Member
    Connecticut
    Not sure what fuse it was the bike has been running fine so I am no longer digging into the issue. I'm busy riding. I described the location of the fuses and what they look like. I'm sure it was related to the fuel pump.
  14. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    You should keep digging of you want to avoid the possibility of being stranded. Fuses don't blow for no reason.
  15. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
  16. blackvfr
    blackvfr New Member
    Connecticut
  17. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    You need to dig deeper then - there's a good chance you'll be stranded again if you don't take care of this now.
  18. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    So it is your main fuse. The main fuse holder is extremely failure prone. A lot of the time the fuse and fuse holder will actually melt, with out the fuse popping, due to poor contact and arcing.
    The main fuse is supposed to be 30amps...
    I wouldn't be surprised if your fuse/ fuse holder/ wiring shows signs of heat.
    You need to cut the fuse holder out, cut the wiring back and install a high quality 30amp marine grade fuse holder.
  19. blackvfr
    blackvfr New Member
    Connecticut
    I understand that. But I prefer to keep riding. I'm sure it was caused by the super HID head lights the previous owner installed, which I mentioned earlier. I just won't be using the highbeams for now, and once the weather changes for the worse remove them and go back to stock. If fuses blow with the stock setup then I will dig. Appreciate the concern of course.
  20. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
