2006 VFR800 Died on first night ride...
Discussion in 'Mechanics Garage' started by blackvfr, Jul 25, 2016.
  1. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    #41
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    #42
  3. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Suit yourself dude, but it seems kind of silly to me that you know there's an issue and you're not fixing it. That's just asking for trouble.
    It only takes an hour or so to actually fix this problem - much better than hours on the side of the road and having to deal with it later. It's far easier to be pro-active in the comfort of your own garage than out on the side of a highway without all the comforts and convenience of home.
    #43
  4. blackvfr
    blackvfr New Member
    Connecticut
    I think I replaced that fuse with a 25 amp instead of the 20 amp that was in there. I will go up to 30 amp if that is what's recommended. It seemed like 20 wasn't enough for a fuse that can cripple a motorcycle.
    Sent from my SM-N910T using Tapatalk
    #44
  5. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    It is not caused by the HID's. That fuse is not part of the headlight circuit, it is part of the fuel circuit. This fuse holder is very failure prone, even on stock bikes. You need to replace the holder with something of higher quality. The squid lights are not the root cause, but they certainly are not helping matters.
    #45
  6. blackvfr
    blackvfr New Member
    Connecticut
    I did see that 20amp fuse was cooked. So I went up to 25, soon to up it to 30 amp... thanks for that heads up. I road about a mile with those HID on and the 20 amp gave way.
    #46
  7. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    :disturbed:
    #47
  8. blackvfr
    blackvfr New Member
    Connecticut
    From reading some good info the previous owner had the wrong fuse (20 amp) in there, Should be 30 amp which I will put in tonight. I replaced with a 25 amp. Since it's prone to fail it will be upgraded soon enough.
    #48
  9. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Right, we established that earlier in this thread.
    That's not to say that you still don't have other issues. Any new (to you) VFR should get 'The Drill' right away, but that's just my opinion. :)
    #49
  10. Gator
    Gator Member
    Up to what year was the RR a problem?
    #50
  11. blackvfr
    blackvfr New Member
    Connecticut
    I'm in the north east so I'm going to ride the piss out of her till the weather say's otherwise :smile:. This 30 amp swap should do the job till I'm able to perform 'The Drill'. I found what looks like a fuse holder under the seat going to keep a couple spare fuses in there just in case. If it blows the 30 amp I know there some bullsh*t afoot and I will upgrade Sheila accordingly. Yall be safe out there.
    #51
  12. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    All 1-6th gens have old school rr's
    The 7th got MOSFET
    I would hope that Honda got their head out of their ass and put MOSFET on the eighth gen.
    Sent from my Nexus 6 using Tapatalk
    #52
