2009 Honda Interceptor
Discussion in 'Specifications' started by michael, Oct 2, 2008.
  1. michael
    michael Administrator Staff Member
    Kihei, Maui, Hawaii
    It's easy to marvel at the Interceptor's high-tech parts manifest and its state-of-the-art components, including a VTEC-equipped V-4 and exclusive Linked Braking System for starters. It's even more awe-inspiring to ride one. Just ask industry experts, who've have crowned it "Best in Class" 11 times. If you're looking for a bike that puts the "sport" in sport-touring, look no further than the Interceptor.
    The Interceptor's performance profile gets another boost up with its optional Anti-Lock Braking System (ABS), which, when working seamlessly together with the bike's Linked Braking System, delivers controlled stopping power in less than ideal conditions. The Interceptor's transverse V-4 engine delivers smooth, broad power, while the optional Anti-Lock Braking System (ABS) gives you added security.
    VFRworld Photos of the 2002-2009 Honda Interceptor
    VFRworld Sixth Generation Forums
    Downloadable Service Manual
    The Interceptor® continues to serve as the epitome of sport touring motorcycles, one that carries an extra emphasis on sport. Its potent V-four VTEC engine and excellent handling make this the long-range bike of choice for those who hunt out twisty backroads.
    Features & Benefits
    New for 2009
    • New Black color.
    Unique Features
    • Revolutionary VTEC combines the power characteristics of both two- and four-valve cylinder-head designs. The engine runs on two valves per cylinder below 6400 rpm, then switches to four valves per cylinder to deliver significantly stronger low-end and mid-range torque while maintaining the Interceptor's impressive high-rpm power delivery.
    • Unique Pro Arm® Rear Suspension (see Technology Section).
    • Pro-Link® Rear Suspension (see Technology Section).
    • Unique center-up exhaust system incorporates two stainless-steel mufflers tucked beneath the Interceptor's tail section.
    • Large-diameter 43mm Honda Multi-Action System (HMAS) cartridge front fork provides enhanced handling under all riding conditions (see Technology Section).
    • Linked Braking System (LBS) (see Technology Section).
    • Anti-Lock Braking System (ABS) model available (see Technology Section).
    • Four brilliant multireflector headlights employ two centrally positioned H4 low/high beams positioned under two widely spaced H7 high beams for brilliant nighttime illumination.
    Engine/Drivetrain
    • Compact 781cc DOHC 90-degree V-4 with an oversquare bore and stroke of 72mm x 48mm.
    • Silent-type cam-chain drive eliminates mechanical gear noise. The system features a set of dual tensioners that maintain optimal pressure and lubrication for the camshaft chains, ensuring quiet operation and long life.
    • Programmed Fuel Injection (PGM-FI) (see Technology Section).
    • Iridium-tip spark plugs are ignited by compact high-energy coil-on-plug spark plug caps that produce a strong, high-voltage spark.
    • Interceptor engine serves as a stressed member of the pivotless frame, which features specially designed engine mounting bolts tuned to work in harmony with the damping characteristics of the frame.
    • Aluminum-composite cylinder sleeves are high-pressure-formed from sintered-aluminum powder impregnated with ceramic and graphite. The composite sleeves provide better wear resistance and superior heat dissipation than conventional sleeves.
    • Cast-aluminum pistons feature LUB-Coat solid lubricant to minimize friction between piston and cylinder wall.
    • Auto-enriching system is integrated into PGM-FI module, which optimizes the air/fuel mixture on cold starts and eliminates the need for a manual choke.
    • Solenoid-operated dual air-intake duct design keeps one duct closed during low-speed operation to ensure optimal control of air-intake velocity.
    • Dual side-mounted radiators maximize cooling efficiency using low-air-pressure areas created by side cowls to draw cooling air through the radiators. During low-speed operation, a thermostat-controlled left-side fan pulls cooling air across the radiator into the fairing to keep hot air away from the rider.
    • Rugged 125mm-diameter eight-plate clutch offers light weight and high load capacity.
    • Clutch features an offset outside friction plate for quiet operation when starting from a stop.
    • Exceptionally smooth-shifting six-speed transmission.
    • Three-phase coil-spring damper in the transmission provides for seamless upshifts.
    Chassis/Suspension
    • Triple-box-section twin-spar aluminum frame features a tuned, pivotless design that isolates the engine-mounted swingarm from the frame and contributes to handling comfort.
    • Unique Pro Arm Rear Suspension (see Technology Section).
    • Pro-Link Rear Suspension (see Technology Section).
    • The Interceptor's 296mm floating front-brake discs feature a lightweight seven-spoke inner rotor design.
    • U-section cast-aluminum wheels are light and reduce unsprung weight.
    • The six-spoke, 3.5-inch-wide front wheel carries a 120/70ZR-17 radial tire. The five-spoke, 5.5-inch rear wheel sports a wide, low-profile 180/55ZR-17 radial tire.
    Additional Features
    • 5.8-gallon fuel capacity for excellent sport-touring range.
    • The Interceptor's sleek, aerodynamic bodywork is functional and beautiful.
    • Satin-finish treatment on muffler covers and exhaust heat shield for distinctive styling.
    • Stylish silver finish on clutch and brake master cylinders.
    • Clear turn-signal lenses front and rear provide a high-tech look.
    • Air flowing through the windscreen's central air vent provides cool air to the rider at low speeds and increases rider comfort at higher speeds.
    • High-tech instrument display includes electronic tachometer and LCD readouts for speedometer, air temperature, coolant temperature, odometer, two tripmeters and clock.
    • ACG output of 497 watts.
    • Detachable seat provides storage for a U-lock and other necessities. (Lock not included.)
    • Removable passenger seat cowl.
    • Adjustable brake and clutch levers.
    • Injection-molded nylon passenger grabrails are comfortable to the touch in cold or hot weather.
    • Folding aerodynamic mirrors.
    • Transferable one-year, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
    • Purchase of a new, previously unregistered Honda USA- certified unit by an individual retail user in the United States qualifies the owner for a one-year complimentary membership in the Honda Riders Club of America® (HRCA®). Visit Honda Rider's Club of America for details.
    Honda Genuine Accessories
    • Touring Accessories: Hard Saddlebags, Sport Touring Trunk, Saddlebag Liner Set, Trunk Liner.
    ENGINE
    Type: 781cc liquid-cooled 90° V-4
    Bore x Stroke: 72mm x 48mm
    Induction: PGM-FI with automatic enricher circuit, 36mm throttle bodies, and 12-hole injectors
    Ignition: Computer-controlled digital with three-dimensional mapping and electronic advance
    Compression Ratio: 11.6:1
    Valve Train: VTEC DOHC; four valves per cylinder
    Transmission: Close-ratio six-speed
    Final Drive: #530 O-ring chain
    CHASSIS
    Front suspension: 43mm HMAS cartridge fork with spring-preload adjustability; 4.3 inches travel
    Rear suspension: Pro Arm single-side swingarm with Pro-Link single HMAS gas-charged shock with seven-position spring-preload and rebound damping adjustability; 4.7 inches travel
    Front brake: Dual full-floating 296 mm discs with LBS three-piston calipers
    Rear brake: Single 256 mm disc with LBS three-piston caliper
    Front wheel: 3.50 x 17 in.; cast-aluminum
    Rear wheel: 5.50 x 17 in.; cast aluminum
    Front tire: 120/70ZR-17 radial
    Rear tire: 180/55ZR-17 radial
    DIMENSIONS
    Rake: (Caster Angle): 25.3°
    Trail: 100mm (3.9 inches)
    Wheelbase: 57.4 inches
    Seat height: 31.7 inches
    Curb weight: 540 pounds (Includes all standard equipment, required fluids and a full tank of fuel—ready to ride)
    Fuel capacity: 5.8 gallons, including 0.8-gallon reserve
    PERFORMANCE
    Fuel consumption: 34 to 43 mpg, 36 mpg avg.
    Quarter-mile: 11.22 sec. @ 119.80 mph
    Roll-ons, 6th gear: 60-80mph/5.26 sec., 80-100mph/5.82 sec.
    AVAILABLE COLORS
    Black
  2. crustyrider
    crustyrider New Member
    North Country, New York
    sexy, I'd buy one
  3. Wiztigg007
    Wiztigg007 New Member
    Apple Valley, CA
    What the Crap!!!
    Wheres the Ultra sexy V5 we thought we would get?
    That a bunch of :bs: LOL
    Maybe next year, and I was saving my pennies too.........
  4. desertman62
    desertman62 New Member
    Phoenix, AZ
    Ya know, I heard that for 2010......
  5. chris2711
    chris2711 New Member
    Worcester, MA
    I like the blacked out forks, frame, and wheels.
    Looks like a nice gloss black, much better than the sparkle black of 06.
  6. Molsan
    Molsan New Member
    Red Deer Alberta
    It also lost a few pounds?
  7. chomper
    chomper New Member
    Greater Vancouver Area B.C
    what happened to 1000cc we were promised for 09? i guess ill keep my 05
    i wonder what the color change for 2010 will be
  8. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    Daddy like. It's the SCORPIONS edition.Gonna have a bLaCkOut baaby!!!
  9. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    A v5 is a VFV or VFE not a VFR.
    How much would that cost anyway?
    $18,000-$20,000?
    That would price me out.
    I would have to buy a Ducati ST4 or Triumph Speed Triple.
    No thanks.
  10. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    Of course you still have to drop two grand on exhaust,a PC III,and a fender elimation kit but oh well.
  11. namaishi
    namaishi New Member
    San Diego, CA
    What the hell? That doesn't look much different than my black 06!
    I especially like this part:
    New for 2009
    New Black color.
  12. jeff8478
    jeff8478 New Member
    What Tires?
    Does anyone know what the stock tires are on the 09?
  13. NorcalBoy
    2008 Curb Weight = 540
    2009 Curb Weight = 540
    Taken from Honda Website......
  14. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    tires
    From the picture they look like Metzeler Z6 roadtec's
    Hopefully,they aren't Dunlop rimcovers :bs: or there's another $300 on top of the other $2000 in accesories you would have to buy.
  15. Mainjet
    Mainjet New Member
    Southern Ca.
    It's not all bad, my 02 is still a state of the art, current VFR for at least another year.:bootyshake2:
  16. DANIMAL
    DANIMAL New Member
    Metairie, LA USA
    Michael ,
    where did you get this? looks like an ad for an black 06.
    I didn't see the part about the 1000 cc engine option.
    LOL
  17. powerslave
    powerslave New Member
    winnipeg,manitoba.
    Just ran out to look at the Metzeler Z6's I have on my '02 from the same point of view as that publicity shot and the tread pattern is not quite the same from that perspective.:mad:
    So I don't think they are Z6's:unsure:
  18. nozzle
    nozzle New Member
    Southern Maryland
    The DN-01 is the exciting news.... the VFR world continues to turn. Black... just for Henry Ford and Obama... but not the US government's budget.
  19. fotodaddy
    fotodaddy New Member
    Lagos, Nigeria.
    Oh goody!!! So I really haven't lost much with my newly acquired 2008 VFR:smile:
  20. reg71
    Sikeston, MO
    you'd think the aftermarket would be oozing with parts considering the bike hasn't changed in 7 years now. I think honda is going for Yamaha's record with the FZR. How long was it the same? It seemed like a long time... Just the one odd year with the single headlight...
