2014 VFR800 Died and won't restart
Discussion in '8th Generation 2014-Present' started by alexk243, Mar 30, 2024.
  1. alexk243
    alexk243 New Member
    Chicago
    Been riding my new to me 2014 VFR800 standard for a few weeks now, putting on 3-4 hours and maybe 200 miles on it.
    Was riding today and came to a stop at a light and the bike died. Dash shows oil light, check engine light and gear indicator shows "--" and the bike won't restart.
    Pulled off the road and tried what i could. Stand up down, kill switch on off, shifting gears, clutch in/out, and no response from the starter. Does not try to crank and lights do not dim.
    I'm waiting on a tow now. Any ideas on what could have happened and what I need to check?
  2. alexk243
    alexk243 New Member
    Chicago
    Bike has 18000 miles on it and I trust the prior owner took care of it, but history is unknown.
  3. Thumbs
    Thumbs Member
    Bath(ish)
    Does the fuel pump run?
    You should be able to hear it
    Try rotating the key
    alexk243 likes this.
  4. Grum
    Grum New Member
    If No Neutral light? And No fuel pump prime? Plus No cranking, and No horn.
    Equals.........
    Blown - Start/Horn/Stop Fuse 10amp in the Left fuse Box.
    Had you done any recent changes to the front Brake lever or its position by rotating the Master Cylinder clamp position? Can cause a brake switch short to the handlebar blowing the fuse.
  5. alexk243
    alexk243 New Member
    Chicago
    Do not hear the fuel pump. All fuse are fine.
    I did adjust the front lever position prior to ride. Ride lasted 20 mins before issue. Will look for a short there, but expected to see a blown fuse if that was the issue.
    No neutral light, confirmed in neutral.
    Sent from my SM-S901U using Tapatalk
  6. alexk243
    alexk243 New Member
    Chicago
    Disregard, that fuse is blown... showed continuity when tested, but pulled it and it was blown. Guessing there is continuity due to the short. Going to search for that now.
    NT650_999 likes this.
  7. alexk243
    alexk243 New Member
    Chicago
    It is blown. Horn did not operate. I'm towed home already...[​IMG]
  8. alexk243
    alexk243 New Member
    Chicago
    Wish I had the 5mm allen key with me to check on the road... going to add that to the tool kit.
  9. alexk243
    alexk243 New Member
    Chicago
    Replaced fuse, blew immediately once key turned on.
  10. Grum
    Grum New Member
    Have a close look at the front brake switch, are any connections touching the master cylinder or frame in any way?
  11. alexk243
    alexk243 New Member
    Chicago
    I suspect brake switch wires...
    Disconnected both and one side is showing continuity to ground. Are these switches 12v or grounding switches?
  12. alexk243
    alexk243 New Member
    Chicago
    Bike starts and appears normal with brake switch wires disconnected and fuse replaced... now to find the short...
  13. alexk243
    alexk243 New Member
    Chicago
    Black with red wire on brake light switch is showing continuity to ground with bike off and brake lever removed... and thoughts on where to look for the short?
  14. Grum
    Grum New Member
    Switch sends 12v to the rear light assy. Does the rear brake switch operate the lights and not blow the fuse?
    Closely inspect those front switch terminals are Not touching any frame. May need to also check your rear pedal switch.
  15. alexk243
    alexk243 New Member
    Chicago
    OK. Think my testing was problematic... continuity to ground went away with key on... put it back together and fuse is not blowing. I'm guessing it was grounding to the bar when attached.
    Does it sound normal to have continuity to ground from red/black wire on brake switch with the key off and not with key on?
