3 plugs - perfect tan color, 1 plug - dry fluffy carbon
Discussion in 'Mechanics Garage' started by flummerylove, Feb 27, 2012.
  1. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    That plug is fuel fouled, not oil fouled. Squirrellyman has a point. Low/weak spark will not burn all the fuel properly and foul plug. Swapping the coils is a quick test. Possible bad plug wire. Swap that too. Check CDI box connections also.
    If all that checks out then it's back to the carb. Possible wrong pilot screw needle or damaged?? Is this happening at just idle or are you road testing?
  2. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Swap coils/plugs to suss out possible electrical problem, could be just a fouled out plug like said above.
  3. Maggot
    Maggot New Member
    Park Ridge, IL
    With that plug being dry all the time you may not be getting any fuel to the cylinder. Pull the plug wire off that cylinder and run the bike for a minute. Then remove the plug and see if it is wet. If it is still dry, no gas!
  4. Maggot
    Maggot New Member
    Park Ridge, IL
    Check your spark while the wire is off by putting a plug in the wire and grounding it against the engine. Turn it over and look for spark.
  5. squirrelman
    A big, fat, blue spark, not a weak orangeish one.
    A healthy ignition coil should throw a spark about 7mm to ground.
  6. Dukiedook
    Kansas City, USA
    Spark gap checker works well in these situations.
  7. GreyVF750F
    GreyVF750F Member
    Yea....telling your friend "here hold this a second"..................
  8. Maggot
    Maggot New Member
    Park Ridge, IL
    That's the best test.......nothing like a verbal conformation of spark strength!
  9. flummerylove
    flummerylove New Member
    Utah
    Ok swapping them coils now. Haha nice button
  10. flummerylove
    Utah
    The spark on the problem child cyl is throwing about 7mm to frame, but its lookin orangeish. Bright daylight however. The adjacent cyls spark appears to be the same, but that plug is yummy. Will swap coils now. Do coils fade out when they are spent? Ignition wires fade as well?
  11. flummerylove
    Utah
    Grey750f this is happening during road test and idle. Took the bike out for a all day flogger and the problem plug went from dry fluffy black to wet gassy black
  12. tinkerinWstuff
    generally the plugs or the wires IMO. Swapping all three around and seeing where the problem follows will help narrow it down.
    You can probably get what you need for new wires from the local auto parts store. Bring in the old wires to a competent store and they should be able to make up a set to match as opposed to buying from Honda. I know I made a set for my '85 500 and just reused the screw on ends that attach to the coil and the grommet. Haven't paid much attention to what the 3rd gen uses for wires.
  13. GreyVF750F
    GreyVF750F Member
    I doubt it's the coil. Because one coil fires to different cylinders. Your only having problems with one. So it's either the plug, plug wire or resistor in that plug wire end at the plug,which sounds like you have a good spark. It takes three entities for combustion. Fuel, which you are getting, spark ti ignite , which you have and compression. You mentioned new rings. Were the cylinders honed properly? All rings installed right? Does that cylinder have compression and how much?
  14. flummerylove
    Utah
    Swapped 2 coils & wires, problem no follow. Cylinders were honed by the best race shop in town bar none. Pistons were teflon coated and I installed new rings. I was super meticulous about this...however I very well could have screwed pooch on this cylinder. The gaps were in triangles from each other and could have moved upon install. Ring placement can effect compression completely..correct? Could it be the bike was beat to shit before I bought it and the cyls were worn past spec. All cyls would be showing symptoms instead of just one? The V4 is damn tough..this common?
  15. flummerylove
    Utah
    duh improper cyl test. will get at tomorrow.
  16. squirrelman
    It takes a bit of riding to get rings proppaly seated, but if your mechanic didn't check the ring END GAP, something coulda screwed up.
    When do you plan a compression test ?
  17. flummerylove
    Utah
    Thursday I will get a solid comp test done. Rings have about 9k on them. I rode her hard right out of the gate for the first 20 miles then changed immediately. Then a few changes around 2-500 mi. END GAP...now I recall not really giving that eagle eye for some reason. Prolly cuz I was fried from obsessing on crankcase for a week. If the gap is too small...compression issues.... doink :twitch:
  18. squirrelman
    B4 replacing rings you need to measure the cylinder diameter to see that's it's still within proppa specs.
    Also, you need to place each ring squarely into the cylinder about 1" down and measure the ring end gap with a feeler gauge.
    The most likely thing to go wrong if things are not correct is a ring with insufficient end gap expanding with heat, cracking, loosing compression and scoring the cylinder wall.
  19. flummerylove
    Utah
    Precisely what I needed to know squirrelman. That proceedure was not done. I reealy hope I am lucky. Doing comp test now.
  20. flummerylove
    Utah
    I now recall dude at racing shop measuring I.D. of cyls. He would have not proceeded if they were worn past 70.10mm, so good there.
