5th Gen Best Mod$: "Actually Readily Obtainable and Available"
Discussion in '5th Generation 1998-2001' started by Cat2Rider, Dec 3, 2016.
  1. Lint
    Lint Member
    Simi Valley, Ca.
    Please dyno it already. Unless your butt is computer calibrated, a ride doesn't prove much. I'm glad you're happy, but we need hard numbers.
  2. 3dcycle
    3dcycle New Member
    st johnsbury vermont
    please o please let me be the R&D for this on the 6 gen, need to unleash it
  3. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    ~plot twist~
    Cat2rider is actually a motad sales person sent here to act like an asshat and drive down black widow sales.
    Sent from my Nexus 6 using Tapatalk
  4. Cat2Rider
    Cat2Rider New Member
    Paycheck City (Varies)
    It will Dyno between 110 and 115 whp, so what ? Nothing changes
  5. duccmann
    Shot me please
  6. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Cat2rider, what exactly is your purpose in this realm?
  7. duccmann
  8. duccmann
  9. VFR4Lee
    VFR4Lee Member
    Reseda / LA
    One bourbon, one scotch, 1 beer!
    Consider yourself shotted. :glee:
  10. RVFR
  11. RDMCD
    RDMCD New Member
    London Ontaorio
    I can think of worse ways to go:eek:
  12. RDMCD
    RDMCD New Member
    London Ontaorio
    You may be on to something... if you were the head of marketing at Delkavic this would be the perfect way to sabotage your competition!
  13. Lint
    Lint Member
    Simi Valley, Ca.
  14. Cat2Rider
    The Delkevic system is 100% manufactured and fabricated in China and has 4 additional clamped connection to further increase the profit margin by reducing the fabrication welding labor manhour and size of the shipping box. The sales strategy included providing a Dyno report. But with all these cold joint sealed mechanical connections , the sealing compound will eventually fail and the system will leak much sooner than an all welded system. The best practice is to have all welded hand fitted connections like Black Widow
  15. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Black widow has 2 of these "cold joint sealed mechanical connections" made with clamps. Delkivic has four, but the main difference is delkivics connections are spring loaded while black widows are clamps... Anyone who has owned a vfr for a long time and used the two different sealing methods can tell you how much better springs are than clamps.
  16. Cat2Rider
    The Black Widow is an exact (Stainless Steel) true equilvilent of the Honda OEM 08-01 VFR 800 header Downpipes (minus the catalytic converter 00-01). The two clamped joints not "spring loaded" nor would this be appropriate for these clamps are absolutely necessary to facilitate the installation and fit-up of the header pipes to the cylinder head exhaust ports. The particular location of these clamped joints are less prone to leakage because there only are a single inline vertical joint connection located behind the shield with minimal exposure to the elements. Whereas the location of the additional Delkevic spring-clamped joints are underneath the engine in an area with significantly increase exposure to corrosive effects of outdoor elements particularly moisture and dirt. The mechanical clamps in this location will degrade due to the intrusive nature of corrosion on the threads this resulting in a higher likihood of failure due to leakage promoted by the engine emiting high heat with consequential expansion and contraction. Black Widow has taken the necessary extra steps and expense to perform the final fit up and welding in their shop in the U.K. ensuring the header system will fit and not be prone to leakage due to unnecessary additional mechanical clamped joints. These are the simple facts of the matter.��
  17. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Lol absolutely bs
  18. Cat2Rider
    There is an additional possibility that Delkevic also added the clamped joints in order to have the ability to interchange the sections of the header piping between 5th and 6th gen VFR's
  19. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Lol you ignoramus, the 5th/6th gen header layouts are identical.
  20. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    These Akrapovic headers must be of lower quality than your team eBay race supplier "black widow" due to all their spring loaded slip fittings, especially at the bottom of the header...
