5th gen running rough
Discussion in 'Mechanics Garage' started by dutchdog1, Jan 29, 2010.
  1. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    What kind of vacuum gauges do you need for the syncing the starter valves? my buddy has some old style vacuum gauges, not sure which kind or make they are. Last time I saw them used was to balance the carbs on a ST1100, wonder will they work on the vfr?
    #41
  2. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    A vac gauge is a vac gauge
    Just the adaptors you might need to sort out
    I bought a set of el cheapo ones from chi-na only had 5mm adaptors, had to make 4 x 4mm ones to fit the VF, don’t matter what they read, just as long as they all point the same direction
    VF1000F2F, in bits
    #42
    VFRIRL likes this.
  3. ridervfr
    Not sure that is gona solve your problem, the way I understand/look at it is if it is like synchronizing my carburetors, that is only good for just a CH off throttle and low speed operation - general idling around town (leaving your pad around the neighborhood.) Once your off that spot, upper rev zone etc, it does'nt matter if your carburetors/starter valves are synchronized to perfection (like mine are : ) I could be wrong and don't profess to know what the Fu*k I am doing (self taught with stealership thrown in for gud measure.) This is what I use https://www.carbtune.com/
    #43
    VFRIRL likes this.
  4. Waylander
    They are another type of vac gauge, as long as they all sit at the same level all is good
    The idea is if the butterflies are in sync at tick over they will be right through the rev range
    I don’t know enough to say if it will fix you running issues or not, but anything is worth a try,
    But as it has a FPR it must be fuel injection anyway, I would see if you can borrow your mates fuel pressure regulator, see if that fixes it
    VF1000F2 a work in progress
    #44
  5. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    We'll see, I'll start with the starter valve scync. Hopefully I'll get her running right eventually.
    #45
  6. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    I posted on another thread that I just discovered one of the starter valve sync tubes was disconnected from the airbox, so hoping that this vacuum leak was the cause of the bike running rough,
    I have set the idle at 1200rpm with bike well warmed up, but the rev needle does fluctuate a bit, is this normal?
    #46
