6th. Gen front brake locking up
Discussion in 'Mechanics Garage' started by Tori, Mar 14, 2008.
  1. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    It may have been a fluke. I'd bleed it to flush out all old fluid, and ride with that bleeder wrench in my pocket (or at least in the tank bag). It may never do it again, but you never know.
  2. elf800
    elf800 Banned
    dallas
    well ed a stuck caliber could be cuased by the fluid build up forcing pressure on it (caliber)and it got hot swelled and got stuck remember if metal expands it then can get stuck so the posabilty of heat cooling down after being pulled over also contributed to the caliber releasing.bottom line piston was pushed out therfore brakepad touches rotor right rite then after math is a mystery ?? sorry i wasn't there to elaborate for everybody? only few things make a caliber push the brake pad out force from master cylinder satan or debrie hit it or rust made it stick for a quick pulse i ride with middle finger on front brake index on clutch motocross maybe a slight pull created the problem??? and it froze but lets go drink some paote and walk through the spirit world and we will then find the answer until then its all mechanics lever master cylinder line piston calibers rotor thats all folks.......:yield: it.......blah :blah: :blah: :blah: :smash: :smash: :smash: :smash: :smash: oh w8 a minute u know wat it waz fool air in da line wata noob................:panda:
  3. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    Out of curiosity, do you have a shop manual and are you following the step-by-step bleeding process? I got out my manual to get a better understanding of the LBS arrangement and how everything inter-related, and was a bit taken aback by all of the steps required...
    And when you had the original problem, did you have to open any of the left hand side bleeders, or just the right? I'm not trying to beat this to death; just trying to get an education...
  4. Cjarava
    Cjarava New Member
    Phoenix
    I had this same exact thing happen to me yesterday!!! However, after I applied the front break again, it unlocked. Weird. I'm taking it to the dealer tomarrow.
  5. eddievalleytrailer
    Jonesborough, TN
    My money is on a bad master cyl. It is not allowing the front brake to release. I'm sure the dealer will figure it out.
    Keep us posted, Eddie
  6. Tori
    Tori New Member
    Grover Beach, CA.
    I still haven't cured mine..... nor done anything to cure it. After talking it over more with SLOVFR, Im going to change out the front brake lines. It possibly is damaged from the tumble the bike took last year. The right clipon was broken off, I'm thinking maybe the hose is damaged internally and not allowing fluid to return properly. (partially collapsed)
    Im hoping i can buy just the front lines from Galfer. Anyone know ???
  7. eddievalleytrailer
    Jonesborough, TN
    Is it still doing it? Does the lever still lock up?
  8. Tori
    Tori New Member
    Grover Beach, CA.
    yes.......
  9. eddievalleytrailer
    Jonesborough, TN
    I wouldn't say that it's not the brake lines if they were crushed in an accident. But, my money is on the Master cyl. I've seen it several times before. I can't wait to find out for sure what is going on with your bike. Keep us posted with any updates. GET IT FIXED before it wrecks you or strands you on a busy, narrow road, and you get ran over by a blonde in a sports car talking on a cell phone while putting on make-up and reading the Enquirer!!
  10. Tori
    Tori New Member
    Grover Beach, CA.
    ............mmmm....sounds sexy. What a way to go. :biggrin:
    But seriously, im gonna start with the brake line. If i upgrade to steel braid and it doesn't fix it i wont be too upset as i want to do that upgrade anyway.
  11. eddievalleytrailer
    Jonesborough, TN
    Yeah, Sounds like a good excuse to upgrade.
    Hey, if you're going to get run over anyway, better her than Bubba with his beat-up Dodge truck not paying attention because he is trying to find his spit-cup.
  12. Lgn001
    Lgn001 Member
    I'm curious to see where this one goes, too. I'm still on the fence about keeping the '07, as much as I like it, but the techno-gadgetry makes maintenance more than I'd like it to be.
  13. dizzy
    dizzy New Member
    MN
    I just read this thread...thought I'd "dredge" it up cause I think I have some useful information. If you take the cap off your master cylinder you'll see two holes, one large and another teeny one. If that teeny one is obstructed, a brake system will do EXACTLY what yours is, Tori. My understanding is that little hole provides a place for brake fluid to go when it gets hot and expands. I've come across this same thing a handful of times over the years. Bleeding probably won't help...rebuilding the master cylinder may...if in the process you make sure that little hole is open. Hope that helps.
  14. eddievalleytrailer
    Jonesborough, TN
    I agree 100%. I feel sure that rebuilding the M/C will fix your problem.
  15. csb
    csb New Member
    Tasmania
    Just a couple of options, insufficent clearance between brake lever/master cyl piston, dirt residue blocking compensating port in master cyl or internal blockage in brake line.
  16. Tori
    Tori New Member
    Grover Beach, CA.
    Thanks for the ideas guys,... i'll have to check the tiny hole theory. Although the system has never been open, so i dont know how debris/dirt could be in there. The next step is to remove all the lines and send to have them duplicated in SS. Both which require time and money i dont have right now....
  17. Tori
    Tori New Member
    Grover Beach, CA.
    UPDATE: I just installed new Stainless Steel front brake lines on the bike. The bleeding process went totally normal. No issues bleeding whatsoever. I will give it a test ride tomorrow and we'll see if it acts up. I'll keep you posted.
  18. reg71
    Sikeston, MO
    Boy, they could have gotten that length a little shorter there going over the fender for you. You gonna fab up some kind of mounting system for that? Does it flop around? It looks like it might get in the way underneath your front cowl, but I don't guess there is anything to catch on there... You know, I'd almost like it better if both the right and left line ran down the fork legs... maybe. It's hard to picture... I need to see it in person...
  19. Tori
    Tori New Member
    Grover Beach, CA.
    Yeah, the crossover piece could be about 1-2" shorter. I've told Spieger about it, so the next ones they make up would be shorter. I haven't tied any of it down. That was just a pic showing them right after install. I haven't even ridden it yet. ........thats whats planned for today at lunch.
  20. mello dude
    Iran, Islamic Republic of
    Well - while we're kabitzing the T piece could be taller so the cross-hose comes strait across the fender and stock clamp can grab the fitting. Its tough for a sano fit-up without the bike in hand.
    MD
