6th Gen Heli Bar Install - See It Before You Try It!
Discussion in 'Mechanics Garage' started by ottrod, May 31, 2008.
  1. carlgustav
    carlgustav New Member
    Heart of Dixie
    +1 to what skimad4x4 said ... I started with Genmar's, went to Helibars, improvement was worth it ...
    ACE
  2. jimlowe
    jimlowe New Member
    Devon England
    Cheers for that mate,thats answered my other question say those on fleabay and wondered if they would fit :)
  3. duccmann
    +1 on the Heli's...favorite saying is when it comes to comfort. ..don't be cheap in the wrong way. Not sayin you're cheap by no means bub
  4. jimlowe
    jimlowe New Member
    Devon England
    Trouble is Helibars here in the UK are over $430 !!!
  5. motohockey
    motohockey New Member
    Les Cedres QC
    Hi...its me again...just remembered that previous owner had heated grips insatalled...maybe the mechanic removed the damper and did not put tabs back i!!?? Didn't seem to cause any trouble...wonder how important a role these tabs play!!??
  6. walket6678
    walket6678 New Member
    My VFR that I bought last year came with the Helibars. Can someone tell me if the bars have to be down and touching the triple clamp or can they be slid up and tightened to the fork for a higher bar rise? Seems safer to have them all the way down and secured but I recently raised them up some and I like the bar position much better. Thank you
  7. Merlot
    Merlot New Member
    Philippines
    Angeles City, PH
    Great post, it keeps goin' and goin' and goin'.
    It will live forever.
  8. u wish u could ride
    u wish u could ride New Member
    I slid my stockers up to even on top the day i bought mine home .haven't had a problem, I was shown the trick from a buddy who did the same on his black bird he rode of 50k miles like that.no worries . if your cables can handle it then your good.
  9. duccmann
    Yes, slide them up bud, much more comfortable. If ya need a picture let me know
  10. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    Heli's, genmars, Lsl ?? can't bloody decide which!! anyone got a used set of 5th gen genmars for sale?
  11. Merlot
    Merlot New Member
    Philippines
    Angeles City, PH
    I have HeliBars, don't expect a big change. Subtle difference.
  12. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    what height/leg are you Merlot? looking at the cycle-ergo.com site,trying to figure out if it's worth the cost/hassle.
    do the helis have bolts in them that sit into the upper fork triple the way the oem bars do to stop them spinning around, or do they just rely on being clamped tight round the forks?
  13. Merlot
    Merlot New Member
    Philippines
    Angeles City, PH
    5'8", 180 lbs., inseam 30 inch.
    Heli same as stock bars in construction. Can't spin. (easy to mount on wrong side, left for right, my mechanic was able to reverse mount them, LoL) Yes, they are marked right or left.
    In an upright position, the throttle is just into the mid-finger, have to lean in to get total control.
    Hope this helps....
  14. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    Thanks Merlot, I wasn't sure if the Heli's had the same fitting on the bottom side that sits into the notch in the top bridge the way the oem clip ons do.
  15. duccmann
    Great mod and comfort, at 5'6 perfect reach for me
  16. alexlok
    alexlok New Member
    Thanks to the OP for the detailed write up. I just got my pair of helibars for my recent purchase, a 2005 VFR. And thanks to all the other contributors who have answered most the questions I had in mind.
    I was wondering if any of you use loctite to tighten the helibars to the fork? Or just tighten to the recommended torque readings without loctite?
    I'm probably just going to get a new set of dampers as it's easier for me to deal with (as I don't have a vise and won't bother getting one just for this one operation)
  17. Allyance
    Allyance Insider
    Germany
    East Bay, California
    I got the HeliBars for my 2003, and I also got the "Vibranator" damper inserts which were fantastic. Much better than stock.
  18. duccmann
    Torque--- no use torque hammer or locktite
  19. alexlok
    alexlok New Member
    So I don't absolutely have to use the stock damper? Would save me a lot of hassle
    Anyone else forego the reinstallation of the stock damper and just used aftermarket bar ends?
  20. Laker
    Laker New Member
    Ontario
    I used the Vibranators too, and they do work very well. But check the price, they are more $$ then OEM.
