6th gen rear hugger?
Discussion in '6th Generation 2002-2013' started by WGREGT, Nov 14, 2013.
  1. WGREGT
    WGREGT New Member
    Anyone know why a rear tire hugger won't fit a 6th gen with ABS? All the listings I see for the 6th gen models from all the manufacturers say "non ABS only" for them.
  2. skimad4x4
    France
    French Alps & London
    He He - confusion all around. There is ABS and there is ABS in this case them don't mean ABS they mean ABS - so I hope that clears things up.
    Hint : ABS is also the term for a cheapo type of plastic and the better huggers are made of much stronger(more costly) stuff like carbon fibre hence some sellers like to stress their hugger is not made from ABS... and are obvious to the potential confusion this may cause. Hey ho.
    PS If its designed for your version of VFR it should fit. :faint:
    SkiMad
  3. WGREGT
    WGREGT New Member
    Hmmm...sounds plausible, until I saw that the manufacturers list many types/models/years of bikes for their huggers, and the 02-09 VFR 800 VTEC is the only one that has the "non-ABS" disclaimer with it. No other bike has this listed with it.
  4. WGREGT
    WGREGT New Member
    Just heard from the company...
    "The battery box on the ABS version is different, this prevents the hugger from fitting."
    Huh? This sound right to you guys? Different battery box?
  5. Outboard John
    Outboard John New Member
    Escondido, Ca.
    Maybe go to a parts site and see if the boxes for ABS and non ABS bikes have different part numbers.
    John
  6. WGREGT
    WGREGT New Member
    Yep...looking for it now. Can't see to find the battery box on the fiche. Logic would say it's with the battery, but these fiche things don't run on logic. Step = footpeg, etc.
  7. Gweglez
    Gweglez New Member
    Southampton, United Kingdom
    I always thought that it was because the hugger helps tidy the cables and the abs cable might not fit or something, battery box sounds plausible too though
    I'm also looking for a hugger compatible with an abs model, so let me know if you genius's find/make one
  8. WGREGT
    WGREGT New Member
    I'm looking at buying a used one from Powerbronze...they are in your neck of the woods...
  9. Gweglez
    Gweglez New Member
    I've messaged the guy who made my CF grab rails about possibly making a CF hugger for the ABS model
  10. tinkerinWstuff
    The battery box is molded as part of the inner fender.
  11. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    I don't think it is the battery box that is the issue. There is bunch of extra plumbing for the ABS brakes as well as the cable for the rear shock preload which may be taking up space that the hugger needs.
  12. WGREGT
    WGREGT New Member
    Well, I checked out the hugger today (from a guy who sold his bike). It was damaged pretty badly on the top...looked like the bike compressed and something gouged it pretty good, so I passed on it. Thanks for the info guys. I'll keep looking for one a little less used...
    I DID pick up a flawless silver OEM topcase with keys from him though. Says he got it with the bike and never used it. I believe him from the looks of it. He also had a GIVI screen, but I got one of those when I bought this thing, so I passed on it. Also had an OEM seat and an '04 flat black seat cowl as well.
  13. VFR Love
    VFR Love New Member
    New York
    The gouge could have been from a license plate.
    I have stain tubes exhaust and my plate is bent in an arc and screwed to the under seat wheel well area plastic. It messed up my hugger and even contacted the tire once I removed the hugger.
    There is more travel back there than I think most people realize.
