6th Gen - Will Stock Chain Accommodate a +2 Rear Sprocket?
Discussion in '6th Generation 2002-2013' started by stewartj239, Nov 18, 2014.
  1. stewartj239
    stewartj239 Member
    Syracuse, NY
    For normal use, you are probably right. The fact that the wheelbase and height will change (as pointed out by CandyRedRC46) as you make adjustments during the life of the chain, they are probably not very noticeable. But going from the 43 to 45 might make things a little more pronounced. Once I get it out in the spring, I'll see if I notice.
  2. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    What would be easier to do, fit a 16t front or 45 tooth rear? might try it mid way through this chains life.
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Potato, potahto. But if you change the countershaft sprocket, lube up the splines good with
    anti-seize before putting on the new one. Personally I went with the 45 tooth driven sprocket.
    VFRIRL likes this.
  4. Camp
    Camp New Member
    Easton, PA
    Easier? The rear sprocket. I found 16t front too much so went with 17/45 in steel. A 45t steel was kinda hard to find surprisingly.
  5. ceptorman
    ceptorman New Member
    A stock RC51 will do 205mph!
  6. squirrelman
    doubtful :rolleyes:
  7. ceptorman
