6TH Generation LED Headlights
Discussion in 'Mechanics Garage' started by Allyance, Dec 24, 2013.
  1. zoom-zoom
    zoom-zoom Member
    BC, Canada
    Hey Allyance
    Did the higher power H4 bulbs you installed here have a cooling fan installed or just the larger heat sink?? Also, is the heat sink removable to get the larger rubber gasket in place or did you have to modify the gasket in some way??
  2. Allyance
    Allyance Insider
    Germany
    East Bay, California
    No cooling fan, just a large heat sink.
    I had already trimmed the dust cover for the Cree's, I just trimmed a little more for a snug fit around heat sink.
    The fans on the H7's don't worry me, as they aren't on very much, but with the H4's on all the time, I could see those little Mickey Mouse fans not lasting very long.
  3. Allyance
    Allyance Insider
    Germany
    Preliminary photos:
    New COB H4 - Low Beams
    They appear to be aimed low, left more so.
    COB Low Beams + LED H7 Hi Beams (normal Hi Beam)
    COB Low & High + LED H7 Hi Beams (slight difference)
  4. Skifreak
    Skifreak New Member
    Washington State
    Allyance, thinking of getting the same COB LEDs in H4 for my 5th gen. How would you compare their lighting over stock? Any reliability or other issues since the install?
  5. Allyance
    Allyance Insider
    Germany
    So far so good. After playing with 3 different manufactures, they are brighter, whiter, but I don't think their pattern is as sharp. When you think of it, the filaments in stock lamps are almost a point source and reflectors are optimized for them. The COB LED's are mounted on a larger diameter stalk and have a larger area that emits light. I haven't been out too much in the dark, but do like the instant on and white light. I also think I have to re aim lights for difference in design.
  6. TA-Rocks
    TA-Rocks New Member
    Gettysburg, Pa
    I tried it once on another vehicle, it can burn up the wire unless you have sufficient gauge to carry double current.
    Or did he add another wire?
  7. Allyance
    Allyance Insider
    Germany
    Strange to see my 2 year old thread!
  8. TA-Rocks
    TA-Rocks New Member
    Gettysburg, Pa
    lol Yeah I looked it up. Any new reports of the Cree LED swap? I find that it is only about 50 now. I have been running Sylvania Ultra, but probably should do the upgrade and use less current. I am a fan of LED and use it in the RV. It made a huge difference when I swapped all the 12V lights on it.
  9. Allyance
    Allyance Insider
    Germany
    Traded in the 6th gen in Dec 2014, now I have real LED headlights!
