84 VF1000 gear problems????
Discussion in '1st & 2nd Generation 1983-1989' started by dup's VF1000, May 13, 2007.
  1. daveyto
    daveyto New Member
    Scarborough, Canada
    Jamie I was out riding the bike and am not convinced its gear problems...It feels like clutch...Can you be .01% wrong?
  2. daveyto
    daveyto New Member
    Scarborough, Canada
    The river is called the Nile and its like as large and long as the mighty Mississippi.
  3. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    If it was all the gears or high gears you could say yes, but that is not the case here.
    You know what has to be done to fix the problem, either fix it or don't, wishful thinking ain't gonna magically make it a clutch problem.
  4. crustyrider
    crustyrider New Member
    North Country, New York
    I think he missed it TOE.... the river Toe CUTTER was redering to is the River called Denial or De nial...get it...TOE has a sick sense of humor
  5. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    No kidding! That would be worth a drive up north for sure!
    Hey, I can be wrong just like anyone else. It's tough to diagnose something without having the bike here, but it sure sounds to me like classic gearbox failure.
  6. daveyto
    daveyto New Member
    Scarborough, Canada
    What makes you so sure?
    Is it a common issue with the vf1000? What if I change the clutch and it works...What you gonna say then? Sorry?
  7. JamieDaugherty
    Fort Wayne, IN
    Yes, exactly. Gearbox problems are common on the early VF's and clutch issues are rare.
  8. daveyto
    daveyto New Member
    Scarborough, Canada
    Thanks Jamie!
    No Disrespect intended!
    I was thinking of a way to diagnose this... if I ride the bike and it slips in 2nd gear and I hold the shift lever down with my foot and it catches...then it would be a gear issue...Correct?
    thanks,
  9. daveyto
    daveyto New Member
    Scarborough, Canada
    Thanks for the explanation...We all know Jamie is the expert..I am not questioning that...I need to have this MOFO working so I can sell it or its a partout on fleabay!!!
    DId I mention its a Canadian model...oooooooh
  10. daveyto
    daveyto New Member
    Scarborough, Canada
    wheres BAdbilly when you need him?
  11. zielarz
    zielarz New Member
    detroit
    I got same issue in mine 86 750 parts bike now.... the 4th gear is fucked....shifted fine from first...2...3...and then just grr.grrr.so I had to go higher 5...6.... I think its the....gear inside transmision....4th...tooth or somethink....never fixed..
  12. JamieDaugherty
    Fort Wayne, IN
    Nope, sorry. The gear shift mechanism is not a direct drive. Since you have already shifted into second gear, the mechanism has indexed already. Holding down on the lever does nothing to keep the gear dogs in mesh - that's the shift drum's job.
  13. daveyto
    daveyto New Member
    Scarborough, Canada
    Now why did you have to tell me that.....AWWWWWWWWWWWWWWWW
  14. JamieDaugherty
    Fort Wayne, IN
    Yeah, it's a bummer. Unfortunately what you are describing sounds like the same thing many others have faced also. It sounds like it's time to start searching eBay for some good parts!
  15. daveyto
    daveyto New Member
    Scarborough, Canada
    Would it suffice to purchase 2nd and 3rd gear if I could find them...?
  16. JamieDaugherty
    Fort Wayne, IN
    It doesn't really work that way. You will need to replace the parts that are damaged - which may be from other 'gears'. You see, it's a constant mesh gearbox which means the gear teeth for ALL gears are always together. To engage a particular gear the shift drum slides certain parts side-to-side which engages dogs/slots on the sides of the gears which make the connection. To lock in that gear it requires the help from the neighboring parts. You need to tear the engine down and determine which parts are bad first. If it's anything like the gearboxes I've repaired you'll find more than just second gear is damaged to the point where it needs replaced.
    It's actually pretty easy to know which ones you would need. Just look at the gearbox parts that are discontinued and those will be the ones. My suggestion would be to try and find a good condition complete gearbox, shift drum and shift forks because probably all of them are damaged to some degree by now. The problem will be finding good parts as this was very common (mentioned before) so what you find will likely also be damaged. Be sure to ask for detailed pictures of the gear dogs and the 1-2 shift slot in the drum to ensure there is no wear or damage on the parts.
  17. daveyto
    daveyto New Member
    Scarborough, Canada
    ok thanks...know of anyone in Toronto that I can bring the gearbox to?
  18. squirrelman
    You'll find those good parts on any newer VFR gen.....time to step up ???
  19. JamieDaugherty
    Fort Wayne, IN
    I'd ship the gearbx to Dave for the undercut service. He does great work and is as cheap as anyone (even cheaper, in fact). As for the shift forks and shift drum, you are going to have to find good used parts. I've been thinking about ways to repair these parts but currently do not have an option for that.
  20. daveyto
    daveyto New Member
    Scarborough, Canada
    Whose Dave?
