84 vf750f turn signal problems
Discussion in 'Mechanics Garage' started by airgreesemonkey, May 10, 2008.
  1. masonv45
    masonv45 New Member
    No it did not
  2. miner64
    miner64 New Member
    thank you
    and the guys behind the counters are all like that with the deer in the head light look when you ask for a part for something older that tey are. Lol
  3. squirrelman
    Be sure to clean the turn signal switch contacts by spraying a cleaner then a lube into the slot the button rides in, and work it in by cycling the lever left and right. Dirty contacts will prevent the lights and flasher from working. :confusion:
  4. miner64
    miner64 New Member
    Thanks for the reminder i will do that when i pick up the flasher and i will get some cleaner and contact lube as well
