85 VF500 jet kit?
Discussion in '1st & 2nd Generation 1983-1989' started by WGREGT, Dec 3, 2009.
  1. invisible cities
    invisible cities New Member
    new york
    air filters - slight detour
    On a side note - does anyone have the 'rest of the story' on K&N air filters?
    A Honda Factory Mechanic I know frowns upon them. Beside the need for re-jetting for little gain in HP, his take - 'more air, true, but at a price' - noting that more particles can get through and damage the engine.
    I would appreciate any thoughts!
  2. tinkerinWstuff
    It is stock. The bike ran better in warm weather and ran like hell in cool weather. Regarless, it never ran "right" for me. I made the change specified and it now runs great. I also ride at 4000 feet and above. Mostly 4800 feet to 8000ft so I require a leaner mixture than most. Regardless, 90's suckied for me. I think my motor's compression is on the lower end of the factory spec so that could have something to do with it.
    You said "any thoughts".... I haven't used one yet, but I'd think that if the K&N *really* killed motors, there'd have been a lawsuit by know from someone. That's the arguement used by doubters and planted by people who want to sell traditional filters. My question would be, show me one proven engine to have been killed by a K&N?
  3. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    i have yet to see any other number to suggest mine is low if you could get me real world number and not what the claimed hp rating we might have somethin then
  4. invisible cities
    new york
    mid 50's
    True real wheel horsepower is in the mid-50's when using the larger 32mm bore carburetors. The '86 dropped down a bit but this model year should still be above the 50 HP mark.
    Based on posts I have read on the Yahoo VF500F Owners Group.
  5. matt1986vf500f
    when my bike was dyno it had no slip-ons on it and most likely dirty carbs, who knows why its that low i'll be dynoing it again in the spring so ill found out if it comes close to the 50 mark
  6. invisible cities
    new york
    slip-ons
    Good deal - I'm sure you'll get things dialed in and I look forward to reading what you find out.
    On a side note - I've read that slip-ons actually rob power or at the most - after re-jetting - they'll even out to stock horsepower.
  7. tinkerinWstuff
    Still lookin, but this site has dyno printouts from a V45 750 showing over 60HP. Using that as a benchmark, I'd say the 500 should realistically produce 50.
    http://www.math.uwaterloo.ca/~rblander/moto_long.html
    still looking....
  8. matt1986vf500f
    no like my factory mufflers where not on it at the time :eek:
  9. slowbird
    slowbird Member
    Toronto, Ontario.
    You Dyno'd it without a complete exhaust??
    You can toss those "baseline" numbers out the window :tongue:
  10. matt1986vf500f
    well to make a long story short i i had a leaking header gasket pull it all down fixed it and i screwed up the gaskets for the slip-ons and the atlanta bike show was like a couple of days away abd bikebandit couldnt get them so i said screw and rode it up to atlanta with out them :thumbsup:
  11. slowbird
    slowbird Member
    Toronto, Ontario.
    In your defense those Muffler gaskets are a PITA
  12. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    It looks like I'm a little late to the party.
    Honestly, I would try just simply shimming the needles first. The stock main yet is ok even with a 4-1 header. The mains are not lean with the stock setup, and a 4-1 doesn't require much more fuel on the top end. In some cases I've had to bump the jets up one size, but that's it.
    Jets are common and cheap, as are washers from the hardware store. A jet kit can help make optimum power if dialed in properly, but you can get 90%+ without one most of the time.
  13. invisible cities
    new york
    jet sizing
    Good advice, thank you for the post.
    Regarding the stock main jets, you note that they are fine even for a 4-1 header. Are you refering to the stock #90's?
  14. JamieDaugherty
    Fort Wayne, IN
    Of course, it all depends on the rest of your setup and the year (carb version). For most of my bikes I've found that the stock main jets are pretty close. With other changes, such as an aftermarket air filter, you might need to go up one size.
    Without special equipment , reading the plugs is the only way to know where you are with top end jetting. There usually isn't one 'special formula'. The best you are going to get is a good starting point to begin your tuning from.
  15. invisible cities
    new york
    jetting
    Well noted, thank you.
    I'm still a little puzzled though why the '84's 32mm carburetor was released with #102F/#105R main jets while the '85's 32mm carburetor is set up with #90's front and rear. The '85 set-up seems like a significant reduction from what the stock engine can handle.
    Honda must have dialed in the '84's 32mm carburetor for the larger mains - perhaps as part of the change the '85 carburetor also has different jet needles and emulsion tubes - to go with the smaller #90 main jets?
  16. TRX250R
    TRX250R New Member
    R.I.
    Now, if your carbs are dirty, just cleaning them should make your bike run richer, right? My problem is when my bike gets hot, it wouldn't stay running, I don't thing its the pulse generater (sp) cause as long as I hold the throttle it will run, just wont hold an idle. I'm thinking it may be running lean cause of the F1's and K&N filter. I have yet to pull the plugs though.
  17. matt1986vf500f
    your pulse generater's most of the time fail on the top end
  18. slowbird
    slowbird Member
    Toronto, Ontario.
    I have a Hindle 4-1 I can get for cheap locally....but I don't wanna get it for the reasons of having to muck with the carbs.
  19. TRX250R
    TRX250R New Member
    R.I.
    So the bike would stall while cruzing down the street?
  20. WGREGT
    WGREGT New Member
    What's "cheap" ?
