85 vf500f running on 3 cylinders.
Discussion in 'Mechanics Garage' started by Quizno88, May 23, 2017.
Tags:
  1. Quizno88
    Quizno88 New Member
    checked the spark and changed the plugs. that's fine. it's gravity fed but still only seems to run on 3 cylinders at idle. when I rev the engine the exhaust blows out normal and seems to run fine. new to this bike so any help would be great. coming from having a 05 gsxr750.
  2. Mind_Surfer
    Mind_Surfer New Member
    VA
    I recommend remove carburetors for thorough cleaning cleaning, and fuel tank also. I fought with my 500 for quite a while before I got it right. Running on two or three cylinders it was.
    Sent from my XT1031 using Tapatalk
    Correct he is. Start reading about the correct way to remove and clean your carbs you will.
  4. Quizno88
    Quizno88 New Member
    carbs where cleaned by a master mechanic who is a good friend of mine. should I take them off again and go through them is there a link to how to do it properly?
  5. Quizno88
    Quizno88 New Member
    it's also gravity fed with the vacuum line bypassed. it drops plenty of gas so I thought it was working fine.
    Use Search. Read. Search. Read. Ask questions about what you don't understand (after searching and reading).
    Then ask "the Master" if he did all the things that you read about.
    Then read some more.
    And then , yes, do it yourself (if you have the tools and skills) so you know it's done right.
  7. Mind_Surfer
    VA
    Yes after my own experience, I would in particular have a close look at the slow jets. They have such a small orifice, and clog quite easily.
  8. Quizno88
    Quizno88 New Member
    ok thank you i'll be back when I get around to messing with it. hopefully tonight.
  9. squirrelman
    unless you've poked a .012" steel wire or guitar string through the slow jet you can't be sure it's clean ! Inspect the plug from the lazy cylinder, and if it's black, you might have a leaky float needle.
  10. Quizno88
    Quizno88 New Member
    the plug I pulled out was black. I'll look at that tonight hopefully.
