85 VF700 Fuel Pump Relay
Discussion in '1st & 2nd Generation 1983-1989' started by MB85VF, Jun 4, 2014.
  1. MB85VF
    MB85VF New Member
    Hey guys,
    Having the erratic fuel issues that alot of folks have experienced.
    Cleaned the petcock which eliminated some variables.
    Reattached with clear hose so I could see what was happening and sure enough it turns out that my fuel pump is working SOMETIMES. I was just about to buy a new generic unit when I realized it could be the relay.
    I don't quite understand how the unit works, or how to test it, so thought I may as well ask for some advice.
    Mike
  2. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    If it works like the 86 relay chuck it and jump it.
  3. RotaryRocketeer
    RotaryRocketeer New Member
    OKC Metro, OK
    +1,000,000
  4. MB85VF
    MB85VF New Member
    Electrical is my main weakness. How can I bypass it but keep the fuel pump on?
    Mike
  5. RotaryRocketeer
    OKC Metro, OK
    Your year and model may vary, but on the '86 you just disconnect the harness side from the relay and put a length of wire between the two terminals. This will provide constant power to the pump. If it turns out that it works well this way, just tape up the connection, forget about it, and resume normal activity. There are probably a few threads around here that would have a picture.....
  6. squirrelman
    Connect black and blue/black wires at the relay plug, tape it up, and ride. After the bike sits for a day, you should hear the pump clicking as soon as you turn on the key.
  7. MB85VF
    MB85VF New Member
    Thanks fellas will try today
  8. MB85VF
    MB85VF New Member
    Look like it was the relay. Pump works solidly with the black to white jumped. Cheers for your help
  9. Glenngt750
    Glenngt750 New Member
    Edmonton, Alberta, Canada
    There was a reason Honda put a relay in that pump wiring. Probably because it consumes a lot of amperage. You can buy relay kits for cheap. I was told a relay uses "small power" to control "big power". It uses a small amount of power to open and close a switch that controls the power to the fuel pump. With direct wiring it could cause excessive heat. Not a good thing around gasoline! I'd at least ask a Honda mechanic at a dealership at your earliest convenience. There must've been a reason to put a relay on there in the first place?!
  10. FMB42
    FMB42 New Member
    Unless I'm mistaken, the relay is used as a safety device that only allows the fuel pump to run while the engine is running. Thus, the fuel pump will not run in the event of a crash or if he key is left on with engine off.
    This is why these are often called "fuel pump safety cutoff relays" in the auto, boat, and motorcycle industries.
  11. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    The fuel pump only runs when the 2/4 coil fires. The pump does not work 100% of the time. You can find fuel pump relays on ebay pretty cheap. I have one if you need it but I won't get back from my trip until the 16th of June or close to there.
  12. MB85VF
    MB85VF New Member
    It seems to be running as soon as the bike is switched on. I'll definitely monitor the heat situation, but I was under the assumption it was a safety mechanism also.
    Ebay seems to have relays priced about $30, which I don't think I'm willing to pay for an untested used part. Has anyone used an aftermarket relay?
    I'll totally take you up on the offer when you return if I'm not sorted by then, thanks.
    Mike
  13. garageking700f2
    garageking700f2 New Member
    I'm having a similar problem, how did this turn out for you?
  14. NormK
    NormK New Member
    From what I have read the fact that the pump only fires on the 2/4 coil it is switching on and off constantly and this is what burns the points out, imagine how many times a second the pump is on and off at 10,000rpm. Food for thought
  15. squirrelman
    Junk food cuz your assumptions are incorrect. Relay stays on until coil pulses cease but does not cycle on-and-off.
    The above makes no actual sense in practical application. None !
    Why run a relay when it's one more item that can fail and leave you stranded ?
    After numerous problems over the years I have bypassed and eliminated the pump relay on all my Hondas without exception.
  16. NormK
    NormK New Member
    I can see the reason why they fit the relay because if the engine stops and the ignition is still on then without the relay the pump will keep running but at the end of the day it causes more problems than it solves so the best thing is to get rid of it and take your chances that if you do drop it you get the ignition shut off quickly. Life if full of compromises
