86 VFR orphan rescue
Discussion in '1st & 2nd Generation 1983-1989' started by chuntera, Oct 16, 2019.
  1. chuntera
    chuntera New Member
    Connecticut, USA
    Removing the steering stem was a classic episode of man vs. nut; 3/8" ratchet? nope, 24" breaker bar? nada, electric impact driver? not happening, HEAT + impact driver: winner! Man then celebrated victory by making a grilled cheese sandwich.
    Here's the steering stem & yokes removed. Note the lower stem bearing is lacking grease. I used the Michelangelo method to remove the bearing races (ie. hammer & chisel).
    #41
    atx and sixdog like this.
  2. chuntera
    chuntera New Member
    Connecticut, USA
    Forks are WIP
    Here is detail from the lower race. You can see a small indentation, it doesn't look like much but you could feel it turning the handlebars.
    There was a similar notch on the inner race
    I used a dremel cutoff disc to remove the inner race from the steering stem. I only needed to cut through the thinner section of the race for it to let go. This left the race in good enough shape to use as a drift to bang the replacement into position. v4dreams has a blog post about this.
    #42
  3. chuntera
    chuntera New Member
    Connecticut, USA
    So I punted on repainting the brake calipers but decided to do the fork lowers. They had some corrosion and fair number of chips.
    I used a 180grit abrasive wheel to remove the paint and deep scratches. Then I went over it with #320 wheel to smooth out the dips/waves from the #180.
    In the photo, left is after #180 and right is after #320
    Next came wet sanding with #400
    After cleaning, I put on a coat of etching primer followed by three coats of black appliance paint then let cure for about a week. It's not a pro shop quality paint job but I can live with it.
    #43
    Colddevil and sixdog like this.
    On fork lowers, good prep and a resilient finish is most important. Once you bolt everything on, little quality issues aren't a big deal, it's gonna take some abuse anyway.
    Good job
    #44
  5. chuntera
    chuntera New Member
    Connecticut, USA
    I thought I had posted something here last fall but maybe I didn't hit the save button.
    The frontend is back together. Forks rebuilt & new brake lines. The radiator was disassembled, cleaned & fan shroud repainted.
    I replaced the shorter radiator hose sections but re-used the longer pieces.
    #45
    Bazza, RogueRC24 and sixdog like this.
  6. chuntera
    chuntera New Member
    Connecticut, USA
    The wheels sent to a local shop for powder coating.
    Incidentally I went to order pivot works wheel bearings and found the part no's had changed to all balls :(
    #46
  7. chuntera
    chuntera New Member
    Connecticut, USA
    Last fall my 87 vfr700 started leaking from a fuel tube joint. They were last rebuilt in 2016 by mr. squirrels, so 7 years on a set of orings.
    An extra set of almost-complete carbs came along with this 86 orphan bike.
    So I spent the last 4 months rebuilding carbs.
    The general process
    - steam clean
    - teardown
    - soda blast
    - fix broken stuff/missing pieces
    - ultrasonic bath
    - reassemble
    I sourced some orings and tygon fuel line from Joe @v4dreams and others bits I ordered online.
    The sets had various problems, some fixes were more successful than others. One carb went to a local welder to repair a broken mounting tab. He said the cast aluminum contains a lot of filler metal.
    Here is a comparison of before/after. For this one the intake plenum was blasted with "real" blasting media. Soda blasting is tedious but does brighten the carbs bodies.
    #47
  8. chuntera
    chuntera New Member
    Connecticut, USA
    Over the winter, the wheels went out for bead blasting & powder coating to a local shop. Had to pull out bearings, valve stems, etc. Finally got new the bearings and seals in this week. Waiting for new valve stems.
    Checked out tire options, which are limited in this size. On the upside, 2nd gen tires probably half the cost of new treads for a 5th gen.
    #48
    Bazza and RogueRC24 like this.
  9. squirrelman
    VITON O-rings are the best now, not the older classic rubber stuff.
    #49
  10. chuntera
    chuntera New Member
    Connecticut, USA
    Last year I stripped the old brown powder coat from the engine cases https://vfrworld.com/threads/look-honey-here’s-a-rwb-ya.60861/page-4#post-644018
    Then I put them in a box and promptly forget about them. I rediscovered the box recently and the cases were almost totally oxidized.
    Spent some time wet sanding the worst bits of oxidizidation, then sprayed a coating of etching primer.
    They will be repainted soon. Its almost impossible to get the original textured brown finish with spray paint. I will have to choose something else for a paint finish.
    I recently repainted the cases on my 87 vfr satin black. This was a quick job while I had bits off the bike to check valve clearances and change clutch plates. The satin black isn't bad, it doesn't really pop but it doesn't look out of place either.
    #50
  11. RogueRC24
    For my 88 I just did a general media blast and went with VHT clear. It didn't cost much and I think it looks cool without trying to look cool. lol Engine case.JPG
    #51
    Jim McCulloch and Bazza like this.
  12. Fastdruid
    Fastdruid New Member
    Is that a repaired frame or something else going on? Looks to me like an early frame with some bonus welds!
    #52
  13. chuntera
    chuntera New Member
    Connecticut, USA
    Shelved the engine covers for a while because I can't spray paint worth shit. First coat the paint was too thin and I got runs. Second coat the paint was too thick and I got orange peel. Also regarding paint contamination, don't spray paint in your basement while the clothes dryer is running.
    Instead I pulled the swingarm & shock linkage to clean & lube bearings.
    The service manual recommends moly paste for the upper shock mounting. Not sure why it doesn't do the same for the rest of the linkage.
    #53
    Bazza and sixdog like this.
  14. Jim McCulloch
    Jim McCulloch Member
    Looking good brother....Painting is such a crapshoot unless you have a well ventilated room and plenty of light.
    I would give up painting if I was rich.
    #54
  15. chuntera
    chuntera New Member
    Connecticut, USA
    The swingarm and subframe are back in. I did a general clean-up plus re-greased the swingarm & linkage bearings and replaced the grease seals.
    I'm re-using the old chain and tires for now, they will be replaced later after everything else is back together.
    The wheels have 3M white reflective tape, its not obvious in daylight but shows up in headlights.
    #55
  16. chuntera
    chuntera New Member
    Connecticut, USA
    Finished painting the engine covers. I painted a black base then sprayed on a low gloss clear mixed with a yellowish-bronze mica powder. A final clear coar went on top of the mica coat.
    The result is somewhat reminiscent of ther original textured colour. The low gloss helps to hide my painting mistakes.
    I did a bunch of tests with mica powder to find something I liked. The stuff in the bottle has almost no relation to the final product.
    The one on the left is yellow-bronze powder I used, the right is an orange-bronze test piece.
    #56
    Love it. Nice application.
    #57
  18. atx
    atx New Member
    That came out about as good as my powder coated set honestly as far as color match goes. Looks great. IMO trying to color match to a surely faded part anyway is not needed, make it close to whatever you think the brochure color shows, call it good.
    #58
  19. chuntera
    chuntera New Member
    Connecticut, USA
    Yup still plugging away at this project. Its gradually taking on a motorcycle-like appearance and the part boxes are starting to empty out.
    Various bits have been bolted back on. The repainted engine covers have been installed. The front valve cover picked up a few scratches during installation but not the worst I have done.
    Installed a SH775 voltage regulator and facet solid state fuel pump. I cut a notch out of the rear fender for the larger regulator.
    I also wired in a couple mini relays for the headlight. I tapped into the existing power wire from the battery leading to the igntion for the relays.
    Swapped to LED dash bulbs (except the fuel light) & added a turn signal relay that works with LED lights.
    Last weekend I installed a battery to check polarity on the LED bulbs (they only install one way). All the handlebar switches are working but the neutral switch is dead. I tested the starter motor by grounding the neutral switch.
    Yesterday I installed the 4-1 exhaust connecter. To line everything up, I had to loosen the rear cylinder exhaust header pipes which was a tricky job involving a mini ratchet with 6" extenstion and a universal joint.
    The carbs aren't installed so I put painter's tape over the intakes. My garage residents routinely eat through the tape and leave little reminders this project has overstayed its welcome.
    #59
    Bazza and Captain 80s like this.
