86 vfr700 has power but won't turn over after slip on install.
Discussion in '1st & 2nd Generation 1983-1989' started by Snosk8luke, Aug 28, 2020.
    Typically when a solenoid clicks it means it's working, but there are exceptions. That plug needs to be your first priority imo. But don't forget what sixdog mentioned about the diode, he's had it happen. I've never had a diode go bad on my bikes, but that doesn't mean shit.
    Pictures!!!
  2. Snosk8luke
    Snosk8luke New Member
    ok Thanks! you guys are referring to the clutch diode? I tried looking up the "diode" but canT find it nor where it's located on the bike... is it called something else part wise?
  3. Snosk8luke
    I'd also like to mention that the bike has a bypass of some sort from the PO where it does not matter if it's in gear or if the kick stand is down and it will still crank... Not sure if that helps.
    Sounds like the clutch lever switch or the neutral switch has been jumped.
    Pictures of exhaust!!!! How many times do I have to ask?!!!!
  5. Snosk8luke
    ok ok
  6. squirrelman
    diode is located just above the battery on the right side........just where the fsm says. ez to test with a meter.
  7. Snosk8luke
    So I get 3 of the exact same picture. I'll take it.
    Good looking VFR, exhaust came out good. Bet it sounds good too.
  9. squirrelman
    FSM outlines testing procedure for solenoid. doesn't make much sense to replace it b4 it tests bad.
    how many miles on ur bike ?
  10. Snosk8luke
    It's not as loud as I wanted but it's ok... Wish there was a way to remove the baffles.
  11. Snosk8luke
    32000. solenoid and plug are ordered so if anything it's preventative main. Ill let you know if it fixes my prob.
    No you don't, those are already thru baffles, but just on fairly long mufflers. Some more noise from that V4 is good, too much is bad for everybody in the long run.
    squirrelman and Snosk8luke like this.
  13. Snosk8luke
    I wonder if I need an ohm meter? I pulled it and hooked up a 12v light tester to it but couldn’t get the light to come on by touching either prong. Not sure if I’m even doing it right. I’ve looked high and low for a diode just to buy but can’t find anywhere that has them... any ideas?
  14. squirrelman
    sorry but u can't expect to own a honda'cycle without also owning a multimeter and knowing it's basic operation. the diode was fitted on multiple hondas over dozens of years, should be easy to find one, another item that's ridiculously easy to test.
  15. Snosk8luke
    For the sake of not sounding like an asshole, why on earth would you write all that and not be helpful? None of what you said is helping my progress.
  16. squirrelman
    ^^ idiot ! :nelson:
    it's easy to spot one when he wants to remove muffler baffles.
  17. Snosk8luke
    Wow... Did you literally resort to name calling behind your keyboard big guy?
    Anyways, thanks for not helping and making it harder for first time older honda bike owners to learn about their bikes. You're why forums get such a bad shake. Yes, my questions were probably silly to a know-it-all Big Shot VFR owner like yourself, but I'm super new to the game and on a tight budget, I have to learn most everything from scratch and try to fix issues myself.
    When you're not helpful and would rather call me an "Idiot" because I don't know some of the simpler things, it's just not helping. My opinion of course. I for one do not think you're an idiot, I just think you could be less of an asshole... again, my opinion only.
  18. squirrelman
    now that u got that off ur chest, read the service manual, where alot of ur questions would be answered.
  19. Snosk8luke
    I hate you so much... and I bet you’re so squirrell looking. Not good looking at all are you bud? Life’s been rough... I don’t have that problem. Wish you the worst asshole.
  20. squirrelman
    your kind of idiocy and personal attacks are practically unknown on this forum. :(
    NO SOUP FOR YOU !
