86 vfr750 carbies
Discussion in '1st & 2nd Generation 1983-1989' started by craigm, Oct 31, 2013.
  1. craigm
    craigm New Member
    Hello
    Can anybody tell me if the later style carbies will fit onto the 86 model bike? And has anyone done this?
    Had a mishap with a pilot screw seized in the housing, resulting in damage to the carby housing and still have a stuck screw. Parts for the later bikes seem a bit easier to obtain.
  2. TOE CUTTER
    As long as your talking gen 2 your all good, not sure what years were sold in your country. Gen 3 and up were quite different and not gonna happen.
  3. squirrelman
    How bout a photo or two of the problem area craigm ??
    Some differences between '86 and later gen carbs is a big increase in over-all size with larger bore and more solid construction throughout.
  4. craigm
    craigm New Member
    I got hold of a set of 1988 carbs that look very much like the 86 ones for my bike. when I measured the throats and the heads there is an increase in size on these carbies from 40mm(same for the inlets on the heads) to 44mm.
    has anyone performed this fitment and what inlet rubbers were used to go between the carbies and the heads?
