87 VFR 700 f2.....dead spot mid range....need help!
Discussion in '1st & 2nd Generation 1983-1989' started by trfdp3, Apr 3, 2012.
  1. JasonWW
    JasonWW New Member
    Hou. TX
    Hey Toe, my stock needles are worn down and I plan to replace them. Would you recommend OEM needles over the dynojet parts. The OEM cost a bit more, but if you think they are better, I'll go that route.
  2. Chris71Mach1
    Chris71Mach1 Member
    Grand Prairie, Texas, United States
    I have a stage 2 (yes, dynojet DID make a stage 2 for this bike) dynojet kit in my 87 model 700, and it's ran rich as hell since it was installed. I obviously need to have it dyno tuned, but should I have the needles replaced in the process??
  3. TOE CUTTER
    You can see the WILD difference in the taper on the needles from stock to Dynojet, there is no way to get around that. If you want a smooth range of operation stock is the only choice.
  4. Chris71Mach1
    Chris71Mach1 Member
    This just makes me wonder how the stock, non-adjustable needles would work with a set of jetted carbs, considering they're already allowing so much more fuel through the carbs than stock. Would the stock needles actually be adequate to allow/measure enough fuel to compliment the larger jets that would be installed with a jet kit (especially a stage 2)?
  5. TOE CUTTER
    You can shim the stock needles to desires height. I would only use OEM jet sizes as well. It has been mt experience that a little is a lot when making changes to jetting.
  6. squirrelman
    Try adjusting the clip or adding a washer to tune out the flat spot. Experimentation and a few carb r&r's may be needed. With dyno time and washers for adjustment the flat spot could be minimized at least.
  7. Chris71Mach1
    Chris71Mach1 Member
    You wouldn't just happen to wanna come to Texas sometime soon and tune a lowly 87's poor little carbs now, wouldja Toe? ;)
  8. TOE CUTTER
    I would like to, Texas is great, but a bit oot of the way.
  9. squirrelman
    Too damn many bitin, stingin bugs in Texas !! :stung::livid::mad::cower::eek-new:
