'87 vfr700 fuel pump help PLEASE
Discussion in '1st & 2nd Generation 1983-1989' started by jahlov420, Aug 8, 2010.
  1. tinkerinWstuff
    Thanks NCB. When I posted up, I was debating whether I had the the time and energy to chase the formula down myself and get the actual number or go with my approximation. Laziness won out.
    Thanks for going easy on me. In the end, it appears to remain a fair comparison as the OP purchased a pump rated 2-3.5 PSI (even tough I doubt he'll run a 1" fuel line :biggrin: ).
  2. dehning
    dehning New Member
    Lakeway (Austin), TX
    Well to reiterate, I ran a 1000cc '88 CBR1000F for as long as I owned it with the fuel pump discarded and running gravity feed. I don't think I'd go racing with it like that and I was commuting so I wasn't running it to the redline all the time, but it ran just fine. So a 750 should do OK too.
  3. tinkerinWstuff
    Didn't work on this VF
    http://vfrworld.com/forums/1st-2nd-generation-1983-1989/31375-pump-me-please.html
    Orientation of the tank, the size of the fuel lines, location of the petcock, distance to the carbs all have an affect. You're talking a different bike and only considering cc's in your assumption. Overwhelming consensus on the forum is that you will have problems trying to gravity feed a 700+cc on the VF platform. Searching the forums, I have yet to find one person say it's worked for them.
    (aside from Donald who's not running a stock setup).
  4. dehning
    dehning New Member
    Not that I'm disputing the fact on a 750, but how much is supposition and how much is actual fact ? If a couple of guys said they have tried it themselves and it didn't work, then that's good enough for me.
  5. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Norcal- you sure you have taken a fluids class or really understand fluid dynamics? A tank on top of a refrigerator 6 foot high would have more static head than a tank only 1 foot off the ground with lines attached. Also if you add dynamic pressure in to either one of these tanks you would have more pressure, period.
    Bernoulli's equation- look it up.
  6. donald branscom
    donald branscom New Member
    Guerneville CA
    That is not what I meant.
    If you have fuel injection, you have to have a fuel pump.
    If you have carbs you do not need a fuel pump as long as the gas tank will feed the carbs.
    Some bikes will need a crossover line between the two sides, depending on the design of the gas tank. Read that TWICE.
    All gravity feed bikes have fuel filters.
  7. donald branscom
    Guerneville CA
    Not the stock gas tank. Right.
    I have two 1/4 petcocks on each side feeding one 3/8 line to the carbs. With a filter.
  8. tinkerinWstuff
    Some of the VF's used a screen inside the fuel rail as a fuel filter. You have to pull the carb assembly to clean. When using an external, easily replaceable, fuel filter, you add restriction to the system and a fuel pump is generally recommended to prevent possible starvation at long runs of higher RPM (think freeway operation).
  9. donald branscom
    Guerneville CA
    Yes I did look that up and as a former jet engine mechanic I understand some of those principals.
    But he is refering to inviscable fluids at mach speed.
    Anyway this is just a gas tank on a motorcycle. If the gas tank is above the engine and there is a petcock on each side it should work.
    And I like to keep things simple. Why add a fuel pump if you do not need one.
  10. tinkerinWstuff
    WTF are you talkin about Willis? someone missed something somewhere.
    We aren't talking about adding something - say in the case of your project bike. We are talking about the need to leave something as it was designed by the factory - say in the case of the OP who wants to replace his fucked up fuel pump.
  11. donald branscom
    Guerneville CA
    Sounds reasonable to me.
    But I would still want to know WHY it did not work. For instance would it work if the fuel tank had a crossover line and another petcock?
    But do not add a petcock to a gas tank if you do not know how or do not have the skills.
    NEVER weld on a fuel tank even if you washed it out.
  12. donald branscom
    Guerneville CA
    Yes I understand. I did not know other owners of that same bike had already tried to eliminate the fuel pump. Everybody should just calm down. We are all just trying to help.
  13. invisible cities
    invisible cities New Member
    new york
    Tink, sound reasoning for sure - though I do wonder why Honda used a fuel pump on the '84 & '85 VF500F when it is not needed.
  14. tinkerinWstuff
    They also eliminated the external fuel filter in '86 and left you with the filter screens in the carb.....
    The 750's always had fuel pumps for the next 10+ years while they remained carburetor. As I said earlier, do you really think Honda included an unnecessary part just to cut into their potential profit margin or because they found it was required to prevent problems? Come on - capitalism, greedy corporations, they gave you a fuel pump out of the goodness of their hearts?
  15. donald branscom
    Guerneville CA
    Kawasaki did that also in 2004 when they changed to fuel injection from carbs.
    They still retained fuel pumps from an earlier attempt from fuel injection that was a failure, and then tried again in late 2004. So they could use the same wiring harness.
    But they wanted to have fuel pumps because they could use a mercury switch to automatically shut off the fuel via the fuel pump relay. In the event the bike was in a crash.
    With manual petcocks that was not possible.
    My feeling is that if the accident is so violent that the fuel tank splits open all those fancy switches won't do much good.
    The fuel can get ignited by the hot exhaust pipes, even if the ignition is off.
  16. tinkerinWstuff
    LOL!!!
    Since fuel pumps are wired parallel and not in series, you could use the same wire harness and JUST NOT PLUG IN A FUEL PUMP. Manufacturing companies do this all the time because it's easier to have one standard. Don't have fog lights on your truck but they were a factory option? The wiring connectors are still down there, buy the lights and get the other switch - plug and play upgrade you can do yourself.
    However, I'll tell you all that I figured it out. Corporate decided that they'd throw a fuel pump on there so that it could FAIL and then they would get the service and parts revenue later...... eh? there ya go conspiracy theorists.
  17. jahlov420
    jahlov420 New Member
    Richmond, VA
    hallelujah....the mr. gasket pump had a fitting that was too small for my fuel lines. i needed a 3/4 inch fitting so i returned it and went to napa auto parts and got another fuel pump ($51) that was 3-5 psi with two 90° fittings($11). the pump works and the bike it back to purring like a loin. thanks for all the help. now i need to jack up the bike and put my pirelli sport demons tires on now....i can't wait to hit the mountains again
  18. tinkerinWstuff
    Awe shit, now the tire debate......
    kidding. Glad you're running. I'm sure we'll continue to argue because otherwise we'd have to think about doing actual work.
  19. donald branscom
    Guerneville CA
    Wish you could have posted a photo of the fuel pump just to help your fellow VFR'ers.
    Anyway on to the tires!
  20. tinkerinWstuff
    :thumbsup: you're a good sport Donald.
