8th gen clutch slave cylinder
Discussion in 'Mechanics Garage' started by Roar, Aug 27, 2015.
  1. Roar
    Roar New Member
    Chattanooga, TN
    I'm about to clean the chain on my new 800 and switch to the DuPont stuff. I wanted to get ALL that greasy mess off my bike so I was going to get the front sprocket area, too.
    I notice you have to pull the slave cylinder and supposedly replace the gasket. Anybody ever pulled it? What should I look for...I've read to make sure the piston doesn't fall out, don't operate the clutch...lol...what else?
  2. Roar
    Roar New Member
    Chattanooga, TN
    FWIW, I decided not to pull it for now. I'd still be interested to hear more details if anyone does it.
  3. squirrelman
    You need to be super careful not to over-tighten the 2 long slave cylinder mounting bolts !!!!!! :dread:
  4. Roar
    Roar New Member
    Chattanooga, TN
    Hey thanks. Does anything pour out when you remove it? The service manual mentions the gasket, but not that you have to replace fluid, so I wondered if you really needed a new gasket. Manual is not real clear...
