97 VFR 750 wiring issues.
Discussion in 'Mechanics Garage' started by ratbikelady, May 15, 2017.
  1. ratbikelady
    ratbikelady New Member
    Ohio
    I had taken the bike apart over the winter to rebuild and customize, but now I can hardly figure out where all the wiring plugs back in.
    I don't know where the green ground wires go (first pic) and I don't know where the other end of the black wire that bolts to the coolant tube goes (second pic). Any help is greatly appreciated.
    refer to the FSM for answers.:dread:
  3. Terry Smith
    New Zealand
    I looked in the service manual, section 1 has all the cable run diagrams.
    The ground should bolt to the outside of the right frame member just forward/below where the upper subframe mount bolts on.
    The other end of the cable on the coolant tube should go to the negative battery post I think.
