99 VFR800 - HiMileage
Discussion in '5th Generation 1998-2001' started by novaman64, Jun 27, 2011.
  1. novaman64
    novaman64 New Member
    Looking at purchasing a VFR (or Triupmh Sprint or Ducati ST2). The misses has been going on rides with me and is not happy on the back of a CBR... Still wanting something sporty though, so was looking at a VFR, then I could throw some luggage on and a backrest for longer rides when she is gonna join me.
    Anyways, dont have a ton of money to spend, and found a 99 VFR800 for $2,000 but it has 65k miles on it. How long do these motors go? I have done a ton of rebuilds so that doesnt worry me, but does anybody know what piston/rings/gaskets cost to do a rebuild?
  2. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    I would be more concerned about the maintenance than the mileage. There is a guy over in the UK that put 400k miles (not km) on his VFR before he swapped the motor and put another 400k on it.
    I don't think you would need to rebuild a VFR with just that many miles on it. If you are worried about it, after you buy it do a compression test. Then you most likely will no longer be worried. :biggrin:
    I met a guy that had 160k miles on a 99 VFR. The paint was a bit faded. The engine sounded really good. <shrug>
  3. novaman64
    Cool, that is awesome. The guy is the 3rd owner and has only put 2,000 miles on it, but has all the service records from the previous 2 owners, so basically from the time it left the dealer... Probably going to go look at it tomorrow evening.
    Is $2000 a fair price for one with that many miles?
  4. tinkerinWstuff
    yes it is. good luck
  5. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    If it looks decent and sounds good I would buy it on the spot. I paid $3800 for my 98 two years ago. I would say I overpaid... still, it's not a lot of money for a great street bike.
    Just in case you don't know, the whining you hear while it is running is the gear driven cams and that is normal.
    Here is a link to my 98.
    YouTube - ‪1998 Honda VFR - Delkevic Stainless Steel Slip On‬&rlm;
  6. raptor2a
    raptor2a New Member
    Yeah, jump on it if it is in decent shape. Great price. Has it been down that you can tell?
  7. novaman64
    Going to go look at/test drive it tomorrow. Its about 1.5 hours away from me. It has been painted, and the owner said the prior owner had made it into a street fighter so he put it back to original and painted it, but not sure if hes lying about that and it had been crashed or not. Has a clear title though. I will look at the frame/pegs/engine cases to see if there is any obvious signs of being layed down.
  8. wbsprudels
    wbsprudels New Member
    Greenwood, IN
    Good luck, sounds like it might be a good deal!
    Sent from my Eris using Tapatalk
  9. Rangerscott
    Rangerscott New Member
    Texas
    Hers what the FSM says on the cylinders. An aluminum P/M (powder metal) composite sleeve is used in place of a conventional cast iron sleeve. It is composed of a mixture of powdered argil (alloy of silicone, iron, copper, and magnesium), aluminum oxide and graphite (semicrystalline caron). The sleeve is prodeuced by a hot extrusion process, and cast into the cylinder block as with a conventional type of sleeve. The adoption of this aluminum P/M composite sleeve contributes to lower engine weight, along with the other innovations, and enhances cooling efficiency around the engine (by lowering temperature through enhanced heat radiation efficiency), enabling a higher compression ratio. If the temp is managed correctly, the sleeves can be rebored in the same manner as conventional sleeves. During crankshaft and piston assembly and disassembly, make sure that the big end of the connecting rod does not contact or damage the inside surface of the sleeve. Finger typed with Droid X. This tested my patience.
  10. Badbilly
    If you have the VIN check it out via the NADA site. My question would be how many owners? How many miles really, A new paint job? A dealer bike?
    IMO keep looking, this one sounds like a beater.
  11. Rangerscott
    Texas
    I skipped past the streetfighter part. I stay clear of those. I know it's not always squids on them and could just be that he didn't have the money to buy new plastics, but I'm always cautious with those.
  12. michaelt863
    michaelt863 New Member
    Heed Good advice given on All above threads! W/care & maintenance that motor will run Gr8 till the cows come home!!! Enjoy!
  13. Badbilly
    I agree. Take the bull by the horns.
  14. wgash1
    wgash1 New Member
    Victoria Australia
    i'v got 240,000 ks up on my 99 mod, the motor is completly original, but i have had three regulaters + 1 stater in that time
  15. rccaulfield
    rccaulfield New Member
    Wow-does the clock reset to zero at 100k or keeps going?
  16. Rangerscott
    Texas
    Keeps going.
  17. wgash1
    wgash1 New Member
    Victoria Australia
    yep it keeps on going.....but l wish my electrics would :mad: l just recieved my new regulater of ricks, its the new 50amp mossfet type, nice looking unit, a bit smaller in size than the original ones.....pitty l didn't do my checks before ordering it, because it was my stator that was the problem, so l'v just ordered one of those from ricks aswell, so the tally now is 3 regulaters and 2 staters
  18. bobthebiker
    bobthebiker New Member
    funny, people dont seem to realize, ANY motorcycle, as long as it recieves good care, absolutely will last just as long as a car. I've heard of one or two Harleys, and multiple Kawi Concourses, an 01 ZX9R, and an F4i hitting 100-190k miles, and someone who did 400k on an old BMW R90.
    proper care and good maintenance are crucial. most bikes dont ever get the chance to even hit 30k because some squid wrecks em and destroys em.
  19. wgash1
    wgash1 New Member
    Victoria Australia
    +1 to that, l'v only ever used the honda mineral oil GN4 with 5000k changes which works out every 3 mths roughly, but just about everything else as per the recomended service intervals and never had a problem
