adj the drive chain?
Discussion in 'Mechanics Garage' started by sunofwolf, May 15, 2014.
  1. sunofwolf
    sunofwolf New Member
    The shop adj my chain a bit tight. I pushed up on it and it has maybe a inch of freeplay-you think that is enogh? It was loose before maybe 1.5 inch deflection.:mechanic::alien:
  2. 34468 Randy
    Book says 1 to 1 3/8" so you should be OK.
  3. TNRabbit
    TNRabbit New Member
    Woodford, VA
    The manual calls for 1" when on the center stand.
  4. sunofwolf
    I guess it ok. I had the fork oil changed out to belray 7w HP mineral. I went on a short ride, the forks did seem better. My mods to stock suspension so far are only Belray fork oil and scotts damper with excellent M5 Metzler tires. I am finished going though the bike. I am going to add a stock air filter and change the oil soon and add GPS to the tank bag. I am setting it up to do so light touring with only soft bags, tank bag. I have basically finished. I want to upgrade the brake pads however as I think they grab too fast-no rush though. I think it important to take the time to see what works good then rush and do things poorly. So far everything has work:spider: very well.
  5. Allyance
    Allyance Insider
    East Bay, California
    How old is your chain? I am going to replace chain and sprockets next week because when I adjusted my chain it appeared OK, then I spun rear wheel and chain got tight then loose again, I have some links that are binding. Make sure you have same slack all the way around.
  6. sunofwolf
    the chain is in excellent shape for sure at 5300 miles-it well oiled too with belay clean chain stuff.
  7. ZEN biker
    ZEN biker New Member
    Assiniboia, SK
    Just new fork oil is a good way to make the bike feel better.
    I went with oem pads up front and chose ebc copper pads for the rear. These are a metalic pad so they have a better bite for if you ride two-up. I kept the fronts on the oem organics since there are two calipers and twice the braking done up front. Also having the back lock up isnt as much of a problem as if the front locks up.
  8. Robclo
    Robclo New Member
    ON
    "excellent M5 Metzler tires"
    I strongly agree, the best stick and feel out of anything else I've tried.
  9. sunofwolf
    Metzler M5 are made for a heavy bike-those steel belts do wonders-I don't know how they are able to make them work so well-I imagine the tires will last pretty good too-I think they are some where between a sport and a touring tire which matches the VFR so well-. I made up a new type of bike name -I call it a endurance sport bike. :eek-new:
  10. Badbilly
    Great! How many times will we be reminded of your newfound creativity? So far you have a way to go with the drops, pothole and slider posts. Maybe Honda Inc. will hire you as a copywriter. Forget Metzler they require some basic knowledge of tires.
  11. sunofwolf
    yes bad billy.
  12. Badbilly
    Just for that I am not going to tell you how to adjust your chain. You hurt my feelings.
  13. sunofwolf
    :banana: Just Kidding Bad Billy-now how do I adj the chain-I really want to know your secrets.
  14. Badbilly
    Nope. You'll just have to take it to the dealer again. The secrets of my technical skills are too arcane to share. I can give you some hints but you will have to have a foil hat on to receive signal.
  15. highway star
    highway star New Member
    North Mississippi
    You'd be surprised how much slack in the chain is taken up once your full weight is on the bike.
    I do final adjustment with me on the bike, 240 lbs worth.
  16. Badbilly
    Now that is one I would ask to see a picture of. I figure there are some special tools involved or you have very long arms.
  17. highway star
    North Mississippi
    LOL. Yea, how about "final measure" with me on the bike.
  18. sunofwolf
    so when the bike has weight, the slack changes if your really heavy.:topsy_turvy:
  19. Badbilly
    I can't speak for SOW but I will cut ya some slack..;)
  20. sunofwolf
    The chain will not cut you any slack if when you sit on it-the chain is too tight. Once a again Bad Billy can't think. I wonder what amount of weight makes the chain tighten up? And at what weight. If your carrying hard bags that will also figure in. Riding weight is what matters as well as how stiff the shocks are front and back. it looks like the stock specs on chain slack are not really spot on. Perhaps the chain could be off as much as a inch. One person said with center stand on-slack is a inch with it off maybe its a 11/4. In any case it would seem to be not so easy to adj the chain dead on for the riding weight. To be spot on, I would say sit on the bike with center stand on and have another person adj the chain. Not so simple is it Bad Billy!:chaingun::spy::nod::banana::heh:
