All Balls roller head stem bearing install
Discussion in '5th Generation 1998-2001' started by TNRabbit, Mar 27, 2014.
  1. TNRabbit
    TNRabbit New Member
    Woodford, VA
    According the service manual, 76 lb/ft. That's what I used on the top nut.
    I tightened the bearing nut really tight then rotated the headset about 50 times to get it seated in then backed off to the suggested 5 lbs pull from the tree.
  2. revguy
    revguy New Member
    North Bay Ontario
    PERFECT ! I am pulling mine apart this winter to replace mine ................ I guess I should be checking the valves to......... ug
