Alternative Headlight bulbs
Discussion in 'Mechanics Garage' started by scootdrums, Mar 4, 2003.
  1. NYMBYSS
    NYMBYSS New Member
    ok, shut up and quit worring,remember you asked for it,lol
  2. kens97sto171
    kens97sto171 New Member
    Cincinnati
    Hey guys.. Just wanted to post this URL for you. I have purchased bulbs from this site several times, always fast to ship, and he has genuine Hella bulbs in various wattages. I use them in my Miata with the Hella E-Code replacament lenses running 90W/130W bulbs, they are great.. and with the E-Code lens you don't blind anybody.
    In the bikes I would NOT recomend going over the stock watts rating, something will melt for sure... But I can tell you that the standard 55/60 Hella bulbs are brighter, and whiter than most... no blue crap... just clean white light at a great price.. like $4.00 And they seem to last longer than the aftermarket stuff.
    http://www.rallylights.com/hella/bulbs.asp
    Ken
  3. KrautBurner
    KrautBurner New Member
    Bremerton, Wa
    I'm sure you got them from PowerBulbs.com
    that's wehre I got mine,
    I like the Osram silverstars better than the Sylvania ones too.
    the osrams aren't tinted blue
  4. Davidvfr
    Davidvfr New Member
    Concord West, NSW Australia
    You should be ok.
    I put 55/60 watt H4's in when I had the '94, had no problems.
  5. raggi76
    raggi76 New Member
    Melbourne, Australia
    hey guys - just replaced my stock ones with the philips gt-150's. Reason - price - for a pair it was AUD $50 compared with the US $120 for the PIAA. 100 times better then stock and are 55/60w. For price would recommend if on a budget - road legal with blue tinge close to bike, but nice bright white after that first 2 metres
  6. FJWinNH
    FJWinNH New Member
    New Hampshire
    Anyone try installing Bi-Xenons?
    I think the ultimate lighting upgrade would have to be a set of true Bi-Xenons. The light output difference would be dramatically brighter. BiXenons have a single HID capsule that gets modified by an electric (solenoid actuated) shield for the low beam. The lower current demand (35 Watts) would be great for extending life on R&Rs.
    I found a place online (in Canada) to get a dual bulb (auto) 5000k H4 BiXenon conversion kit for $289. The single bulb motorcycle kits are only $179, but for the VFRs (having two bulbs) you would need the dual bulb car kit for the full effect. I suppose the only trick would be finding a place to hide 2 Balasts and ignitors in the bodywork.
    http://www.cqlight.ca/catalog/index.php?cPath=69
    I might be tempted to try one of the motorcycle kits on my BMW first, since that only requires one bulb and the headlight is actually worse than the Veefer...
  7. Action
    Action New Member
    Albuquerque
    I just ordered a set of Osram Silver Stars from California Sport Touring. They were 27.80 for a 2 pack. Much cheaper than I could find localy. If I get them by this weekend I'll change out one and take a picture of the new one vs the stock headlight.
    Action
  8. derstuka
    San Diego, CA
    How did this work out Action? I just bought the some H4's from a local dealer (after deciding not to spending 50 bucks for the stock 45/45 bulbs with the different tabs) for like 17 bucks for both. I have yet to ride with them at night yet. They fit nice and snug if you bend the bottom two tabs just right, and then install the retainer clip. They are 60/55, so a higher draw, but from what I have been reading, it will not melt or damage anything.
  9. Spike
    Spike New Member
    keep in mind too, that the SilverStars will not last as long as the ruglar bulb, and no bulb will change the beam pattern too much, that is dependant on the reflector (although it can be changed a little, by the bulb's placement in the reflector).
  10. derstuka
    San Diego, CA
    What are you running in yours? What brand and wattage? I was more worried about the increased wattage draw than anything else.
    BTW, mine are not silverstars....just some generic H4 bulb from Deutschland (Germany).
  11. Action
    Action New Member
    Albuquerque
    Why would the Sliver Stars not last as long? When I researched them they had a comparable bulb life rating to standard H4 and H7 bulbs and had a better color temperature rating. I've had mine since last Aug and would expect them to last for a while longer. I did make sure to get the European spec (Osram) bulbs which from what I've read are brighter. I didn't expect the beam pattern to change but with a brighter bulb it is easier to see at night. I made sure they were aimed correctly and I don't have any problems with on coming traffic thinking I have my hi-beams on. I work all kinds of strange hours and it really made a difference riding home in the middle of the night.
    Edit - Osram Silverstars are brighter than the Sylvania ones (1500 lumens vs 1350), since they have different standards in Europe (Sylvania = US branch of Osram).
    Action
  12. derstuka
    San Diego, CA
    Can you give me a link to where you bought the Sliverstar OSRAM bulbs from Action?
  13. olivino
    olivino New Member
    New York
    Maybe a silly question, but are there brighter lights than OEM that you can use for brake lights in the stock reflector? Another recent thread discussed the LED Hyper-Lites. However, I would like avoid the wiring.
  14. Action
    Action New Member
    Albuquerque
  15. NeverlosT
    NeverlosT New Member
    Narragansett, RI
    For a little more cash (think EBAY like 100 bucks) you can get an HID setup with dual ballasts and H4 bulbs and they arent too hard to install and the system is easily brighter than ANY simple replacement bulb by a long shot.
    Plus they use less juice after startup (or so I am told, no problems yet!!!) and man do they look bitchin.
    Get a set made for a car, the ballasts are a tiny bit larger, but you get two instead of one for 1/3 THE COST!!! you can find room for the ballasts, I did. I have some install pics but need to get them off parents computer.
    I will try and find the brand of mine, but they came from china, but work sweet. try it, you will be souped.
  16. HondaDavidson1090
    HondaDavidson1090 New Member
    Daytona Beach, FL
    For running lights I have PIAA H4 Super Plasma bulbs in my 04 VFR. They look like H.I.D lights. I came across these for free, when I helped clear out the motorcycle shop next to the one I work at. They were left behind, so I put them in my bike and like the way they look. I still run the stock bulbs in the high beams, only because I dont want to buy the PIAA's yet.
  17. Spike
    Spike New Member
    I have the stock ones in there for now, I am going to try the Piaa what is it, "extreme ultra whites." Ran the Silver Stars in my '98 VFR. Still toying with just doing the HID conversion too....
  18. Spike
    Spike New Member
    Don't know why exactly, but they used to say it on the package and under the FAQ section of their website. I also noticed they just came out with an updated version called Ultra or Extreme SilverStar. That specifically is supposed to last longer.
    For me, when I ran them in the '98, and my cars then, it was a trade off. Like anything in life. The cons were that they were more expensive, and didn't last as long. The Pros were a whiter, seemingly brighter light.
    Beam pattern won't really change, as that is more determined by the reflector. And, to a certain extent where the bulb filament sits in the reflector (since that can change by bulb).
    I don't recall ever having a problem with them with oncoming traffic either.
  19. Spike
    Spike New Member
    You can go with the LED lights, but may have problems with your blinker lights, or PIAA does make brighter incandesant bulbs that you can use. Called their something like Ultra bright white bulbs??
  20. Action
    Action New Member
    Albuquerque
    Spike, thanks for the reply. I had heard that some people had problems with short bulb life with the Phillips (US) brand. From what I was able to read they have made some changes that are "supposed" to increase filament life. If I get another year out of mine (16 months currently) I'll be happy.
    I'm thinking of replacing my stock High Beams with PIAA bulbs. I would go the HID route but to be honest I don't think the hassle would be worth the gain. A guy I used to work with converted his Busa to HID and it seemed he was always having problems with one light not coming on. It could have been he used a cheaper kit, or didn't have it set up right, but it kind of turned me off to the HID conversion. YMMV.
    Action
