Another 1984 VF500F project
Discussion in '1st & 2nd Generation 1983-1989' started by rcthirty, Mar 2, 2025.
  1. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Thanks! This is for an '84 VF750 (RC15).
    It's the left side - rear - (#1 I believe) as you are sitting on the bike. Here are a couple pics of the carbs showing the repaired one relative to the others.
  2. rcthirty
    rcthirty New Member
    correct. #1
    Bazza likes this.
  3. rcthirty
    rcthirty New Member
    I'm missing a carb link arm bushing that goes between # 1 and #3
    It a nylon bushing that looks to be really important to keep the carb sync right. Anyone have one or know where to get one. Fabrication would be sketchy. here's the pic.
  4. Bazza
    Bazza Member
    Are these pretty universal for most VFR carbs?
  5. RogueRC24
    You might be able to 3d print one. If I am remembering this correctly, they are just a fitment sleave for the linkage. Send me the dims and I might be able to make something happen. Although I don't have any carbs out at the moment.
  6. rcthirty
    rcthirty New Member
    Thanks for the offer Rogue but the dimensions are so fine I don't have the tools to measure it.
    Let me see if it looks like the VF750 uses the same bush as the 500, I have some 750 carbs that need to come apart anyway.
  8. rcthirty
    rcthirty New Member
    I just found one in my old carbs. I looked before but missed it. Thanks anyway Captain. All good now
    Bazza, RogueRC24 and Captain 80s like this.
  9. rcthirty
    rcthirty New Member
    The fairing kit I'm planning to install
    mello dude, RogueRC24 and Bazza like this.
    Rad.
    You're gonna need some pretty low clip-ons to mount the upper cowl anywhere close to looking good and allowing the lowers to work with everything.
    You got some work, that's for sure. From my experience mounting cowls from other bikes, every problem you solve you create two more.
    Good luck! Look forward to seeing progress.
    mello dude and RogueRC24 like this.
  11. Bazza
    Bazza Member
    You got a new fuel tank too with the kit? Whoa!!!
  12. RogueRC24
    Yeah usually lose turn radius to avoid gauge banging. Sucks. Custom kits can suck, but you got this!
    Bazza likes this.
  13. rcthirty
    rcthirty New Member
    I didn't get a new fuel tank. That is a cover for a damaged VFR400 to hide the damage. I'm going to have to use my original gas tank and repair it, then paint it in the same colors as the kit. Still a lotta work to do.
    Bazza likes this.
  14. Bazza
    Bazza Member
    I didn't know they made "covers".
    Would appreciate some insight into what these are, please. Plus additional pics to help me understand what they are and how they work.
    Thanks! ;)
  15. rcthirty
    rcthirty New Member
    This a link to the eBay site I bough them from
    https://www.ebay.com/itm/276965948044
    Bazza likes this.
  16. rcthirty
    rcthirty New Member
    The carbs are all re-jetted with my kit cleaned and static synced. New boots and there installed.
    Bazza likes this.
  17. Bazza
    Bazza Member
    Link no worky.
    How about the description of the item - as it is written on eBay - and then I can just do a search?
    Also the name of the eBay seller would help.
    Thanks!
    What were the stock jet sizes in those carbs and the new kit sizes?
  19. rcthirty
    rcthirty New Member
  20. rcthirty
    rcthirty New Member
    I'm using the same 6-Sigma kit I used in my first vf500 project and what they recommended. I can look into what the stock and new one's are if you would like. I think I have them written down somewhere. I'll look
